Will these custom sized BBS LM's fit the IS-F?
I told myself I love the OEM rims and no need to change them but always had a special place in my heart for the BBS LM's.
Can anyone tell me if this fitment would work for the IS-F rear?
19x10, +40 offset, 64.1 center bore
- And if so, what size tires you recommend or should I just use stock tire sizing?
- What is the IS-F Center bore dimensions?
- I would still need to buy the front pair of rims if these rears fit so what would be a good size to complement the rear? tire size up front?
thanks in advance fellas!
rick
rick
I believe the Lexus center bore is 60.1 (need hub rings), I'm sure lobux would know.
As far as offset goes for you. the +40 out rear, might be pushing it if you want to use anything bigger than stock tire size. How low are you? Are you willing to shave the fender a bit? if you are then it should work just fine.
Get a 8.5 30 - 38 or 9 35-40 in the front.
thanks for the info, ok so I'm safe as 64.1 will go over the 60.1
Looked up OEM IS-F fitment:
19x8, +45 on a 225/40/19 tire
19x9, +55 on a 255/35/19 tire
I have no problem using stock tire sizes as long as it safely clears the fender. I prefer not to modify the fenders if possible but rolling is an option if needed.
So my rear BBS is a 19x10 so I'm 1" wider and +15mm more aggressive. Would a 255/35 oem tire safely stretch onto the 19x10" rim? I was hoping to run a 275/30/19 rear tire on the BBS LM for the IS-F...hehe
I'm going to talk to my buddy about sourcing the front rims if these look good after test fitment.
thanks
rick
thanks
rick
s4play
IS F (2008-2014)
23
07-25-09 07:00 PM
