Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus IS: How to Install Illuminated Scuff Plates
Step by step instructions for do-it-yourself repairs
The definitive IS-F illuminated door sills/scuff plate installation guide (w/photos)
#31
Received 1,062 Likes
^^ Good to hear you got it done...
Just make sure the new wire and/or tap doesn't touch or interfere with the internal side of the belts...
If it does, use a mini zip tie to ensure the new wire follows the oem wire conduit and is basically out of the way from moving parts.
Also, make sure the tap is in a place where it won't rattle against something![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Joe Z
Joe Z
#32
thanks joe
nothing in the way
but
ive narrowed it down, heres a pic
maybe the noise was always there????
it only happens when the car is on or with two start button presses
if u just push it once the sound will not happen
right after i click in the seatbelt
theres a click in the pillar
I unplug the connector i circled in the pic and it stops
is there a click after u insert ur seatbelt in the pillar?
can someone check for me next time they go for a drive and let me know
cause it may just be a normal thing
nothing in the way
but
#34
Thanks for the detailed instructions/photos. I installed my white sills this past weekend - they look great. I was intimidated at first, but looking back now it really was an easy install. The hardest part was finding someone who carried those low-profile fuses (yes, I blew a 20A fuse on the driver's side
). After visiting 4 Autozones I finally found them.
#35
thanks joe
nothing in the way
but
nothing in the way
but
From your picture my best guess is that it's a plug for an electronic seatbelt pretensioner, and it's clicking while it's working. That might explain why it only happens after 2 start button presses.
#39
#40
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
No problem!! ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Any dealership... This thread should help too![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Finally Installed: 08' White Illuminated Scuff plates & Clear door lights in my IS350
Regards,
Joe Z
Regards,
Joe Z
