Old 12-15-14, 11:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
The definitive IS-F illuminated door sills/scuff plate installation guide (w/photos)
Old 05-30-12, 06:37 AM
  #61
Kumar350
Kumar350's Avatar
How did you wire it to the foot light? Does it dim and brighter when shift from P to D and vise versa
Originally Posted by MSirJet
just finished wiring up my sils... I went with the foot light for the ground, they look great! Thanks for your the posts on this topic!
Old 11-20-12, 11:43 PM
  #62
phlipmod3
phlipmod3's Avatar
Default Illuminated Sills on Passenger Side
Hey guys. Im having problems trying to install the illuminated sills for the passenger side. I got the drivers side going since it already had the connector. I tapped into the black wire in the b panel and connected it to the red wire on the unit then connected the negative which I believe the wire is brown on the unit to the ground wire on the b panel. It still doesnt work. Am I doing something wrong??? I know the unit works because I connected it to the drivers side and it works fine. Please help!
Old 11-22-15, 11:54 PM
  #63
scorpionge
scorpionge's Avatar
great write up.. will put it to use tomorrow!
Old 11-24-15, 08:02 PM
  #64
scorpionge
scorpionge's Avatar
Did the work tonight!!!
Also added courtesy lights on the handles inside
Old 02-29-16, 07:42 PM
  #65
FinLIFE
FinLIFE's Avatar
^best place to get the illuminated sills these days? And also more info of your illuminated door handles please.
Old 04-03-18, 10:10 AM
  #66
BennyISF
BennyISF's Avatar
Where’s the original pics? Need them to install my led foot sills.
Old 04-03-18, 11:35 AM
  #67
ISF4life
ISF4life's Avatar
These are what u want
Rear
Front side shot
Front
Night shot front
Old 04-03-18, 12:23 PM
  #68
BennyISF
BennyISF's Avatar
That’s great but I was looking for the installation pictures lol.
Old 04-04-18, 02:56 PM
  #69
Nuckz23
Nuckz23's Avatar
Rear
Front side shot
Front
Night shot front
wow where do we get these from? These look great!
Old 04-04-18, 02:59 PM
  #70
ISF4life
ISF4life's Avatar
junack japan special order it
Old 05-04-18, 07:41 PM
  #71
andy08isf
andy08isf's Avatar
Originally Posted by IceIridium
Based on the requests I had on my pics thread, I decided to post specific details on the installation of the OEM Lexus lighted door sills.
There have been some confusion on ths installation of illuminated door sills on the Lexus IS (250/350/F). This is due to the different level of pre-wiring done on the car depending on the year, model, or trim of your IS.
Some cars are pre-wired for plug-and-play installation. Some have the plugs but are not grounded properly. Others don't have the plugs at all. On my IS-F, there was a plug on the passenger side that's not grounded properly, and no plug on the driver side at all. So depending on how your car is wired, just follow the relevant section of this guide and it should work on your car.
The pictures indicating "driver" and "passenger" side are based on my IS-F.
To remove sills and B-pillar cover, just pull them off. They're just held on by plastic clips.
Scenario: Has plug, but not grounded properly
Scenario: No plug
Careful handling the + and ground wires! especially since they're placed so close to each other in the plug.
This installation results in a simple ON/OFF function of the illumination. For cars that come with it from the factory, they fade in with the interior lights. If that is your goal, then I suggest grounding the wire onto the footwell light. I considered this option but decided on the door switch because both tapped wires are in the B-pillar, and also based on my experience with a demo IS250 with it the fade-in is so barely noticeable I saw no point in it.
Result:
I want to attempt this, but the photos are missing from this. Do you still have them? Sounds like they helped out a lot.
Old 05-04-18, 07:43 PM
  #72
andy08isf
andy08isf's Avatar
Rear
Front side shot
Front
Night shot front
These look awesome. Do you have a link for their site?
ISF4life (09-05-18)
Old 05-04-18, 07:56 PM
  #73
tas02
tas02's Avatar
They're not exactly inexpensive.
Old 05-04-18, 08:18 PM
  #74
andy08isf
andy08isf's Avatar
Yeah, I imagine special order from Japan wouldn't be cheap.
Old 09-05-18, 10:38 AM
  #75
Kenny88880
Kenny88880's Avatar
I actually did this a little different way, I just went into the back of all the connectors and didn't have to splice any cables. Here is a picture of what I mean, with the wire on the left side going down into the white plug next to the orange wire. You can do this on all of the plugs, just make sure the wire is into the back of the plug securely, test it, tape it up, and you are good to go.
This way might make it a little more manageable for someone who is hesitant to do this.
I
Thank you very much for this write up, it was perfectly illustrated and was exactly what I needed to tackle this job!
Quick Reply: The definitive IS-F illuminated door sills/scuff plate installation guide (w/photos)
