Oil burning.. Low oil level
As Lobux and JoeZ explained, heavy driving of any kind will cause higher oil consumption so expecting it would be prudent.
If you're concerned about excessive consumption, make a habit of checking regularly to chart the loss.
C.
Yes, I plan to check more frequently. Wouldn't it be better to check in the morning in the garage so the oil has time to settle? I would think at the gas station after running the car, alot of oil would still be in the heads...
I'm overly concerned with oil ever since I had my 01 z06. The 01's have an oil consumption problem which ultimately led to me spinning a rod bearing and having to fork out for a whole new bottom end
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I'm overly concerned with oil ever since I had my 01 z06. The 01's have an oil consumption problem which ultimately led to me spinning a rod bearing and having to fork out for a whole new bottom end![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I suggested the station if you've no other choice. Level is the important.
C.
Tech Info Resource
I check mine cold. If its a little low in operation because some of the oil is in the head, I'm not too worried about it. I'm a lot more concerned about it being too high and having the crank froth it into mousse. IME a little low makes more power from less windage.
