anyone know the socket size for the o2 sensors?
Old 09-16-09, 04:51 PM
rutiger
rutiger's Avatar
Default anyone know the socket size for the o2 sensors?
ever regret something almost immediately? trying to install the iss exhaust. quickly it's become a real pita. i have a 7/8"-22m o2 sensor socket and it just keeps slipping off and starting to round the edges.
anyone know what size it requires?
Old 09-16-09, 08:22 PM
MINO
MINO's Avatar
It's a universal, 22mm / 7/8". Are you using the deep socket or shorty version? I tend to have better results with the shorty since it reduces the chances of improper torque angles.
If it's seized in there, soak with PB Blaster overnight, try again with vice grips or small pipe wrench.
Still not coming out, use a torch to heat it up.
Good luck.
Old 09-16-09, 10:09 PM
rutiger
rutiger's Avatar
the socket is longer. only one the parts store had. may need to check napa for a shorty.
gonna let it soak overnight. if that doesn't do it i'll find some dynamite.
Old 09-16-09, 11:26 PM
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Lightbulb
The right 22mm socket for the right results is a must....!!
Originally Posted by Joe Z
The O2 sensors should be removed before disconnecting the mid-pipe bolts or attempting to remove the exhaust sections.
Also, remove only when O2 sensors are ambient temperature...
Below is a visual of the mid-pipe and sensor area. (IS350 Shown)
Below is a visual of the Lexus/Toyota Techs, O2 sensor removal tool design I use, which works perfectly.
Here are a couple of more options, of the same style tool
Snap On Stock#: YA6675A
Good Luck
Joe Z
Old 09-17-09, 05:41 AM
rutiger
rutiger's Avatar
was hoping to avoid that tool as it has to be ordered further delaying the work.
Old 09-17-09, 10:27 AM
javyLSU
2IS OG
javyLSU's Avatar
^Don't cut corners here - if you damage or strip your O2 sensors, it's a VERY costly mistake.
Javier
Old 09-17-09, 10:52 AM
Blkexcoupe
Blkexcoupe's Avatar
The OEM brand crowfoot o2 sensor socket can be found at an autozone. Craftsman also sells a oxygen sensor socket which can easily be found in the automotive tools section, so there is no need to order it when you can buy them locally.
Personally I'd just order the snap on socket and wait.
Old 09-17-09, 12:01 PM
rutiger
rutiger's Avatar
wd40 soaking and lots of f-bombs got it done. gonna wash it up and go drive it!
Old 11-08-11, 03:11 PM
Bulls23337
Bulls23337's Avatar
installing a joe z exhaust soon. does anyone know if this one will work?
http://www.amazon.com/OEM-27110-Oxyg...=5336108637-20
Old 11-08-11, 03:20 PM
SeanGTS
SeanGTS's Avatar
I just ordered that one from Amazon 30 seconds ago (purchased my exhaust a few minutes ago), sure hope it does!
Old 11-08-11, 03:58 PM
Joe Z
Joe Z's Avatar
^^ I noticed recently that some of the off brand ones don't clear the O2 sensor heat sync / shield properly.
I also read a few of the Amazon comments, doesn't look too promising so far..
~ Joe Z
Old 11-08-11, 04:00 PM
SeanGTS
SeanGTS's Avatar
Hmm... Do you have a link to a proper fitting specimen?
Also.. I just ordered the exhaust from Carson... But I thought I heard someone mention free shipping on your exhaust somewhere... just couldnt find it! Edit, sorry to hijack your thread.
Old 11-08-11, 04:02 PM
SeanGTS
SeanGTS's Avatar
What about this one?
http://www.amazon.com/Alltrade-64862...0796864&sr=8-7
Old 11-08-11, 06:12 PM
staman
staman's Avatar
Originally Posted by SeanGTS
Free shipping would have been awesome as I just payed 175.00 to have mine shipped up to toronto.. Funny thing is when I got my first one 2 years ago it was 115.00
Old 11-09-11, 10:39 AM
Bulls23337
Bulls23337's Avatar
Nice find. Anyone? I'd like to order this today so I'll get it by Friday!
Quick Reply: anyone know the socket size for the o2 sensors?
