tein coilovers?
For those of you that have tein coilovers which ones did you use and did you see a gain in handeling and ride comfort? Have any of you with them been to the track and can actually prove they are a better performance? I have teins on two of my other cars and they are the best but I just want to make sure they are really worth it for the F before I invest that kind of money into it since like I said I already have two play cars. Thanks for the help.
Ho Motorsports
I used to have Tein CS coils on my IS350. From my personal experience, they are mediocre at best. One of them started leaking after a year. The lack of independent shock body adjustment alters the spring rate as you lower the car.
If you want to track the car, the stock set up is quite good. All you need is a good set of tires. If you want to enhance the esthetic and get a decent result, then I'd recommend JIC or comparable products (at this moment, there're not many to choose from) which allows ride height adjustments without altering the spring rate.
Terrance
Terrance
Or you can get a shorter shock body such as KW. They have far more adjustments such as compression and rebound. They also have a IS-F setup. There valving is superior to others. Most setups are all great from the coilovers out there. Its mainly up to you on what you want to do.
If YOU want Teins them purchase them. Buy want you want.
All I was saying is that you can get simiarr performance for less.
BCR coilovers can be boguht for much less and offer very similar performance.
KW V3's are going to give you a hell of a lot better performance than the Teins will and probably cost about the same or a little more.
Received 1,063 Likes
I will be trying out some Nitrogen Gas filled coils in the coming week!!
Fully adjustable..
Joe Z
Terrance
Terrance
Sounds like you already made up your mind to go with Tein, so why are you asking?
Tech Info Resource
