Noise from rear when on steep driveways
Old 09-21-09, 10:22 AM
fryedout
fryedout's Avatar
Post Noise from rear when on steep driveways
There is a large clunk/thump/click/bump sound that occurs when I enter a driveway that is steep. I enter it slowly at an angle, 45 degrees, almost feels like I end up on 2 wheels, almost as though the car tilts and sometimes I hear one of the rear tires lose traction. I always enter the driveways very slow and at an angle to prevent the front from getting scratched. Does anyone hear that? I think the sound is coming from near the rear tire. Maybe it is a chassis or suspension issue? Is something loose? Broken?
Thanks for your help.
Old 09-21-09, 10:53 AM
UCrazyKid
UCrazyKid's Avatar
You are on 2 wheels, the car chassis is very stiff and the suspension very tight. it happens, don't worry about it.
Old 09-21-09, 11:00 AM
IS-Fly168
IS-Fly168's Avatar
Yeah!! Your F is High!!! lol its just the rear wheel in mid air, no worries
Old 09-21-09, 11:51 AM
fryedout
fryedout's Avatar
Well it does not sound like something that just happens. It is not very loud though. By steep driveway I do not mean anything crazy, I will post a picture. It is pretty loud.
Attached Thumbnails Noise from rear when on steep driveways-imag0164-medium-.jpg   Noise from rear when on steep driveways-imag0161-medium-.jpg   Noise from rear when on steep driveways-imag0162-medium-.jpg   Noise from rear when on steep driveways-imag0163-medium-.jpg
Old 09-21-09, 02:51 PM
FNMUPN8
FNMUPN8's Avatar
On very steep grades, like twice the size you picture I hear a buzzer go off somewhere in the front of the car. Very strange noise. I've heard this 2 or 3 times. An alarm from the VSC? Anyone else heard this noise?
Old 09-21-09, 03:47 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Sometimes I get stuck in my own driveway!!! One wheel off the ground and no more traction
But mine is more like a motor cycle jump.....
Old 09-21-09, 09:16 PM
bnizzle87
bnizzle87's Avatar
i too had that same experience the very first day i took my F home from the dealership. she went up on my steep driveway, and my rear driver side tire was in the air and spinning like crazy as i tried to steer it onto even pavement. we ended up re-doing the driveway so that it wouldnt be as steep. the loud sound was evident that it was just missing a fourth tire to remain balanced.
Old 09-21-09, 10:05 PM
t0e
t0e's Avatar
I have the same issue in my car (Very stiff suspension setup) and I also hear a loud CLUNK, THUMP, BUMP.
Like the chassis is flexing a lot. I'm sure its just fender panels moving around.
Old 09-24-09, 03:02 PM
ISF FAN
ISF FAN's Avatar
Did I notice KMA plate frames on your F....LA PD?
Old 09-25-09, 09:38 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
You might want to check if the rear rubber isolators on the bottom side of the shock mount, right where the mount meets the top of the spring. Mine were recently replaced under warranty as both rubber isolators have slipped out of place.
Old 09-25-09, 09:41 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,060 Likes on 2,457 Posts
When this happens, just apply the parking brake a few clicks. It will make the differential act as if it has a clutch type LSD and you'll be able to get the car moving even with a wheel in the air. I have done this, so I know it works.
ttsport15
03-13-18 05:56 PM
robbyk
01-27-15 10:04 AM
stafford00
IS F (2008-2014)
13
08-27-14 08:22 PM
wvuguy
RX - 1st Gen (1999-2003)
13
12-29-09 10:23 AM
triplecore
06-06-08 10:53 AM
Quick Reply: Noise from rear when on steep driveways
