First Look: IS-F LSD Swaps w/pics (been happening in Japan)
#46
Joe - yessir, I'm BACKKKKKKK! ![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
So it looks like $3k for the whole rear end and the dealer quoted me $1,300 for the labor...I got the car for such a good deal I might just go for it! Has anyone confirmed that VSC/VDC/CCC/BBB/DDD will all work with the 2010 rear end?![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Peter
Peter
#47
#52
OS Giken should be in next week and install hopefully that week as well... I will post pictures of this install. This will be tested all year for the TIME ATTACK SEASON. I will give you all updates.
#56
trackdood, how's the OS Giken working out for you? are you experiencing any of the clatter that was mentioned earlier in this thread? Is this clatter inevitable for clutch type LSDs?
Another question is will the IS-f rear diff unit be usable for the is350? Does anyone know?
#60
Spring rates are down in the front and up in the rear, and there are larger anti-roll bars, stiffer subframe bushings, and longer bump stops, which effectively increase spring rates when the car is nearing its maximum roll angle. Lexus also lightened the front hubs and control arms and slapped a Torsen limited-slip differential in the rear axle.
