First Look: IS-F LSD Swaps w/pics (been happening in Japan)
#76
No doubt. I already thought of trying to bolt the whole unit in, but it's clearly a no go. Very different sizing. I'd be happy with just being able to swap the spool, but there's not enough information in the service manuals to determine this before pulling a couple of them apart.
#77
Tech Info Resource
Drive shaft won't fit either. I already did the side by side and measured. Distance from the mount points to the front yoke is very different, distance from the mounts to the axles is different...it's not a good idea to try the full swap.
#78
Received 1,063 Likes
^^ Looks like OEM would be the easiest swap...
.. Otherwise you will have to swap the internal unit with OS Giken or Cusco or TOMs..
Jz
Jz
#81
hrm... bringing back from dead...
I contacted a JDM supply store that I used for years (used to be Japandy back in the day on ebay) Said he could get me the OSG for 126,840 yen which is only 1200-1400$ This is the E diff too!
Thank you for contacting RHDJapan and sorry for the delay! I think we can do it for JPY126,840 plus shipping. Where are you located?
So has anyone swapped yet?
#82
The Maker
We will be swapping in an OSG unit shortly and it has been done already with no impact to ABS or VSC. The TCD version is what we will be reselling, this is the multiple drilled clusthc packs which allow fludi circulation and makes things smoother. Contact us for info on the LSD as we are an OSG dealer now. Make sire its the right LSD for the IS-F. Get a part number because that is about 1/3 the retail price.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Christan
IS F (2008-2014)
92
06-04-12 04:22 PM
