Ferodo Brake Pad?
The HP+ pads are much different than the Hawk Performance Ceramic or HPS. The HP+ are a mainly a race pad. And yeah, with the race pad you get some of the main downsides of the HP+ like the noise, brake dust, and they are not too rotor friendly. Plus trying to stop a 3500+lb Lexus is a much different story than stopping a dinky Civic.
as for the hp+ stopping a 3500 lbs car.. I got mine on today and I locked it up easy too.. The bite is INSANE. The noise isnt bad. All I hear is like a slight grinding noise not the usual squeal. They are great almost too great (scary) but it just a matter of getting used to them. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
FYI for those who said its hard to stop a 3500+ car.. I locked mine up at 127 on the straightaway at willow. AND THATS ON R-COMPS.. so they will stop our CARS... my issue is why the abs is not catching that..???
Tech Info Resource
Because that's your job as the driver. Judge traction, drive accordingly. You should race motorcycles, you'd learn a lot about braking effectively (or die trying!)
Its been sometime since this post has been updated. Has anybody had any problems with the Ferodos since then? I believe those are my first choice for my next set of front breaks...
^^^^I wish I could, but at this time, Ferodo doesn't make a compatible sized pad for the ISF. I'm using my DS2500 fronts with stock Brembo ISF rears with no ill effects.
If you want recommendations on rear pads to complement the Ferodo Front DS2500, contact these guys:
http://speed-freaks.net/ag-177932.23...exus-is-f.html
And, though it's not listed on the linked page, Speed-Freaks also carries Ferodo.
Lou
Lou
