Exhaust Tips - Bolt Size
Received 1,063 Likes
Just as a PM'd you.. I suggest you get the correct hardware from Lexus to mount the tip/diffusers..
The length of the bolts are different between the mounting points / locations..
I believe there are 3 different bolt part numbers in total..
(check your local delaer)
![](http://www.sewellpartsonline.com/images/assembly/5136.JPG)
Joe Z
Joe Z
I dont really understand where the part numbers for the bolts are on that diagram. can you tell me what the total 4 part numbers are for the bolts?
Thanks
If I knew them for sure, I would post them here.. but I don't..
Maybe other members that have access to the parts catalog will chime in.
But a Local Lexus Dealer parts dept can look that up in a heart beat for you.
Joe Z
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
6 bolts of part# 90109-06334
2 bolts of part# 90109-06383
2 bolts of part# 90119-06782
2 nut/clips of part# 90179-06349
Then you will need to get the two small L & R black plastic brackets shown in the diagram.
(I do not see the whole part# for them)
Joe Z
jwynn
Performance & Maintenance
05-01-16 07:48 PM
