Resetting the ECU
Old 10-13-09, 08:18 PM
PHXF
PHXF's Avatar
Default Resetting the ECU
Hey guys,
From what I read on this forum, the best way to reset the F's ECU is to pull the ECI1 fuse for a few minutes, replace it, and you're good to go.
I assume this fuse does not affect any of the other electronics on board that have memory?
Also, is the fuse located in the main fuse box?
Thanks,
Old 10-13-09, 08:48 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb Thanks to Lobux...!!!
Its actually TWO fuses to complete the ECU Reset..
IS-F engine bay - fuse box cover shown below with pulled fuses..
ETCS & EFI
Joe Z
caymandive (06-30-22)
Old 10-14-09, 03:42 AM
Splat
Splat's Avatar
you can drain it quicker by holding the brake down, once the lights die you are good.
Old 10-14-09, 07:17 AM
PHXF
PHXF's Avatar
Thumbs up
ETCS & EFI
Joe Z
NICE! Glad I asked! Thank you for the info. Helpful as always!
Old 10-14-09, 07:57 PM
Joe Z
Joe Z's Avatar
Lightbulb
Before or After what step(s)???
There are really only 2 easy ways..
Fuse pulling takes a bit longer, but none of the nav dests. are lost or window resetting inolved, which happens when removing the neg. battery cable..
1 minute in either case.
Its the same as the IS350...
Old 10-14-09, 07:59 PM
Joe Z
Joe Z's Avatar
No problem...
Old 10-14-09, 08:18 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Sounds like you're going to spend more time jumping in and out of the driver's seat rather than doing the aforementioned method above.
Old 10-15-09, 04:41 AM
Splat
Splat's Avatar
after you disconnect the battery joe.
oh and heaven forbid someone try and offer an alternative way to the forum, flipside
Old 10-16-09, 07:29 AM
Juanca
Juanca's Avatar
^^^ But when you disconnect the battery some memory settings are lost.
Old 10-16-09, 07:53 AM
verals05
verals05's Avatar
Only thing I lost was my seat memory and reset the windows.
Old 10-16-09, 07:59 AM
Splat
Splat's Avatar
different strokes different folks!
Old 10-16-09, 08:01 AM
Juanca
Juanca's Avatar
What about the nav destination history and radio stations?
Old 10-16-09, 09:33 AM
verals05
verals05's Avatar
All were still there... Even the garage door opener didn't need reprogramming...
Old 10-16-09, 10:55 AM
LEXUSF
LEXUSF's Avatar
cant u reset it throught the nav screen? there is a back coded page u can access that shows speed, temp, nav codes and radio codes etc.
Old 11-20-09, 05:38 AM
caymandive
11 Second Club
caymandive's Avatar
ETCS & EFI
Joe Z
Thank you Joe and Lobux. I finally decided to do this today. I'm going to drive the car around a bit later to get everything "learned" prior to my final dyno session tonight to test the combination of both the intake/exhaust. This will complete my dyno journal and I better see close to 375whp and nothing less than 370.59.
Quick Reply: Resetting the ECU
