Strut braces?
Strut braces?
I am looking for different options for front and maybe a rear strut brace. do we need one in the rear? i know the front we do. help please!
What companies make them and how much? i know toms is 500 or so for the front but there has to be more options for the F....
Lexus Connoisseur
Tom's makes one for the front. I'm not sure for the rear.
I also got a quote for 500 on the Tom's front. Have not seen any other alternatives. Heard that the front tower alone gives a significant improvement in handling, does anyone have this piece and can confirm?
If it's listed at 38.000 yen ($412.83) in Japan, that's not a bad deal from VIP.
ups - my mistake - just swap the numbers:
53680-TUE20 : FRONT
53650-TGS80 : REAR
as for the picture - never looked behind the carpets - so this could possible be another lexus car. the rear brace model for IS-F (USE20) should look very similar.
i am going to order these braces very soon from japan - i will keep u informed. Personaly i don't think that the rear strut brace will significantly improve handling.
Maybe interessting for some here is the FRONT & MID PIPE exhaust section from ZEES.
A gain of nearly 30 DIN PS aren't bad numbers. Combine this with a open Intake and you should see maybe 40+ horses...
http://www.zees.co.jp/GS/IS-F_index.html
regards
marcus
53680-TUE20 : FRONT
53650-TGS80 : REAR
regards
marcus
The Maker
Is there interest in a product like this, I can put this in the queue. I have a similar product templated out, but demand is hard to gauge. My thoughts are a preloadable brace...to actually put "pull" on the tower.
I know I hear the chassis flex when I pull in and out of my driveway...not sure if stiffer is better or not.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
shabbyblue
11-08-14 06:05 AM
