Battery died
Battery died
So my battery died. When I try to start it, I hear a click noise and my speedometer starts to fade. The 2 bars in the middle of the dash has a low 10% (battery/oil)
I have 3k HID fogs, V-LEDs DRL LED and 8k low beams. Not sure if that's the cause of it? Or the cold weather?
Car is about 7 months old.
I plan to jumpstart it and take it to the dealership, not sure if it's a good idea with all these HIDs lol.
What are your thoughts?
Thanks!
Thanks!
I'm an electronics expert and there is NO WAY IN HELL those mods you have will drain the battery (provided you installed everything right)
Been reading up on your electrical issues - perhaps you should find a pro to do the work because it sounds like you are not very techy....if you have a short circuit anywhere in the wiring it will cause a battery drain.
rick
rick
rick
rick
The Houston Lexus dealerships are **** anyways - won't even change my rear view mirror!
GreggyG
GX - 1st Gen (2003-2009)
50
05-14-21 12:29 PM
