Injen Intake!
Old 02-15-10, 08:59 PM
trackdood
trackdood's Avatar
I have the first released intake and wed, we are dyno'ing it. before and after for results with video and graph.
Old 02-15-10, 09:55 PM
verals05
verals05's Avatar
Awesome... I'll be waiting ^^^^
Old 02-15-10, 10:16 PM
timeToy
timeToy's Avatar
Originally Posted by trackdood
I have the first released intake and wednesday, we are dyno'ing it. before and after for results with video and graph.
There is your problem!
Here is the way to do it to have accurate, reproducible and long lasting results:
- with stock intake:
- reset ECU
- drive a week (your usual routine)
- dyno the car
- install the injen
- reset ECU
- drive a week (same usual routine)
- dyno the car (same dyno, same time of day)
- compare...
Old 02-15-10, 10:34 PM
trackdood
trackdood's Avatar
the car will get dyno'ed several times through out the week and month. I have several other parts going on and it will be at the shop so we will do more then one run. the other parts will not affect the the dyno runs just some drivetrain and suspension parts.
Old 03-05-10, 01:27 PM
ISFC6
ISFC6's Avatar
Any dyno numbers yet?
Old 04-04-10, 10:48 AM
lx470man
lx470man's Avatar
guess not. anyone eles got this intake?
Old 04-04-10, 09:29 PM
trackdood
trackdood's Avatar
FIGS is dyno'ing it when he gets his in..
Old 04-05-10, 09:12 AM
FIGS
The Maker
FIGS's Avatar
Yes should have it today and I will try to do some Gtech testing. Then install and dyno in a week and more gtech testing. back to back intake tests are pretty much worthless since you do not get the LT fuel trim information and compensation. I will also have video and sound clips.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 04-05-10, 09:17 AM
ISFC6
ISFC6's Avatar
Fig
Will you also be performing the same test with the Takeda intake?
Old 04-05-10, 10:10 AM
FIGS
The Maker
FIGS's Avatar
Yessir. I am getting both and will to a time separated dyno for each application with valid real world data.
FIg
__________________
Old 04-05-10, 10:16 AM
ISFC6
ISFC6's Avatar
FIg
Great. I am looking forward to the Takeda Group Purchase, so hurry on up and and get everything together...
Old 04-05-10, 10:50 AM
FIGS
The Maker
FIGS's Avatar
Yeah I can give you guys competitive pricing now, but want to see how the pendulum swings with the dyno results
__________________
Old 04-10-10, 05:27 PM
lx470man
lx470man's Avatar
is there a reason why the takeda is more money when its using part oem box?
Old 04-11-10, 01:25 PM
lx470man
lx470man's Avatar
any updates on some sound clips?
Old 04-11-10, 07:42 PM
FIGS
The Maker
FIGS's Avatar
I am in the process of uploading a video of the Takeda. It should sound similar to the Injen.
I can think of a few reasons why the Takeda is higher priced.
1. Sheetmetal the interfaces to the airbox is more elaborate and thicker. There is more welding and material.
2. There is more welding in the Takeda. The step up is actually welded whereas the Injen is a formed interface on both ends.
3.The Injen uses a Amsoil airfilter which may be lower cost because it is made in higher volume.
4. The Takeda looks to have at least one custom molded silicone coupler. They most likely have to make back their NRE.
__________________
l3randonki
Performance
05-14-08 11:13 PM
Lexizm
Performance
14
10-29-07 08:04 PM
tommy420
Performance & Maintenance
02-22-07 07:13 PM
donktan
29
10-10-06 09:45 AM
Lem144
Performance
03-24-06 10:20 AM
Quick Reply: Injen Intake!
