Lexus IS-F CCS Concept at Tokyo Auto Salon
#61
Lexus Connoisseur
#63
Yup ![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
That's the million dollar question. I think it could be as little as 3500lbs. CC Brakes, Carbon roof, hood, trunk. Seats look a lot thinner. I'm figuring that the front bumper is CF as well, unless they applied the patter around the grille with a wrap or something. Similar train of thought for the front fenders. The interior of the front doors are CF, with the B pillars in CF as well makes me wonder if it's the entire door structure.
#64
Phat Monkey
haha maybe the whole car is carbon fiber except for chasis frame!
#66
Tech Info Resource
IMHO, the IS-F should have weighed in at 3500 and this version should be a Corvette fighter at 3200 lbs.
#67
As little as? Wow. My Supra weighs 3415 on a certified scale bone stock with no carbon fibre at all. You'd really hope in 17 years Lexus could figure out how to make a sedan at the same weight without all the expense of the exotic materials.
#68
Tech Info Resource
I don't disagree with you. In fact, I share the exact same opinion. However, considering the stock IS F weighs 3800lbs, then 3500 really is "a little as". Seeing also that Lexus cars usually weigh less than their competitive counterparts, it's a lesson everyone stands to learn from.
Right after I win the lottery I'll be developing a whole host of titanium parts for the 2UR-GSE starting with crank, rods, and torque converter...
#69
Apparently nobody but Chevrolet knows how to make a V-8 close to 400 lbs producing decent power. The F's engine is nearly 100 lbs overweight. BMW's M5 V-10 is a whopping 524 lbs! The Chevy may have only 2 valves per cylinder, but they make very good power, get very good mileage, and produce class leading power. It's tough to beat them at the V-8 game. Kudos to the LF-A for prodigious power in a light package, but so few will ever get to experience it first hand.
What is the service weight of the UR engine? I'm really disappointed that they are heavier (I assume) than the UZ. The UZs were awesome, in the 300lb-400lb range, so I wouldn't say that Chevy is the only one that can make a decent V8 with good power/weight ratio.
Maybe the packaging techniques used for the LFA engine to make it so compact will find it's way into the next gen of Lexus/Toyota V8s
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
#73
Tech Info Resource
Good luck, Toyota is a bit ahead of you on that Titanium project though ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Maybe the packaging techniques used for the LFA engine to make it so compact will find it's way into the next gen of Lexus/Toyota V8s![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
I think you're confused about the UZ's weight. They're all well over 400 lbs with the iron blocks well over 500. Chevy's LS series are the lightest production V-8s by a long shot. It's not possible to have DOHC and lightness without extensive use of exotic materials.
#74
Maybe for the 2UR, but I had a friend racing sprint cars in the early 90's - small block Chevy - with 16 lbs total reciprocating weight including the Ti rods, crank, and flywheel. I doubt we'll see anything like that from production. Service weight for the 2UR-GSE is 500 lbs even.
#75
Tech Info Resource
all numbers quoted here are fully dressed unless commented otherwise.
552hp lfa's 1lr-gue v10 : ~380 lbs (0.7 lbs/hp) [bare or dressed?]
255hp rx7's 13B-rew rotary: ~400lbs (1.6 lbs/hp) [unverified]
505hp c6z06's ls7 v8: ~460 lbs (0.9 lbs/hp)
605hp carrera gt's v10: ~470lbs (0.8 lbs/hp)
405hp c5z06's ls6 v8: ~500lbs (1.23 lbs/hp)
638hp c6zr1's ls9 v8: ~530 lbs (0.8 lbs/hp)
600hp viper v10: ~550lbs (0.9 lbs/hp)
320hp supra 2jz-gte i6: ~590lbs (1.8lbs/hp)
480hp skyline's vr38dett v6: ~610lbs (1.3 lbs/hp)
