IS-F Brakes
IS-F Brakes
Hey fellow ISF owners,
So I was at my dealer (Keyes Lexus, Van Nuys), and they quoted me $1500 to change my front brakes + new rotors. Is this about right or does anybody know of a better place in Southern California. Any help would be appreciated. Thanks guys!!
You could buy the parts and find a qualified mechanic to do the install for you. Or if you're inclined, you can do the brake job with just a few tools, a couple of hours to spare, and a friend to help with bleeding the brakes.
From what I have heard $1,200 to $1,500 is about the going dealer rate.
Brembo brakes are extremely easy to work on, you do not have to do this work at the dealer, anyone with brake knowledge can do it. It is quite a simple DIY if you are so inclined.
As others have mentioned, shop around for parts, there are better prices to be had for OEM Lexus parts (pads and rotors) as well as other aftermarket options for parts.
Have them measure the rotors and tell you what there thickness is and what the limits are for the rotors. Make sure they are not "up-selling" you into a new set of rotors.
How many miles are on your car and what is your driving style?
Good luck.
Here is a rotor option: https://www.clublexus.com/forums/5152837-post2.html
Search the forum and you will find lots of pad options.
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
Oh, I also have 20,000 on this baby. I would try the DIY thing, but I'm too scared.. I never worked on a car before hahaha
Front pads = $267.15
Front Rotors (each) = $198.34
Rear pads = $162
Rear Rotors (each) = $257
You can try giving Tommy of Musicbox a call to see if he can give you a quote for the "Front Brakes" install job ..
Looks like you can get in done for just about half the dealer price with OEM parts and an install..
I hear ya on the LA traffic.. my front brakes are not going to last much long either ..
Joe Z
Here are some online discounted prices I found for OEM IS-F Brake Parts..
Rear pads = $162
Joe Z
Rear pads = $162
Joe Z
I just replaced mine with Carbotech Bobcat 1521 I believe the compound was very very easy and only took about an hour....was about $400 with pads, brake cleaner, etc..used pre worn rotors with proper bed in precedure..less dust and works better than stock I beleive...and at end laughed at the dealer when they gave me a quote....making about 2/3 if not 3/4 cost of their labor you would be paying them in their ridiculous cost..
FYI...replaced stock pads at 20,500 miles
Did you replace 2 front or all 4 corners? How do you like Cabotech 1521 so far? My front pads don't have much left. Just want to see what options there are.
Thanks,
TP.
Thanks,
TP.
There is a brake thread under construction here:
https://www.clublexus.com/forums/is-...struction.html
Lou
Lou
Any feedback on these carbotech pads?.. I heard that these are pretty good.. keep us posted or PM me.. thanks
