Headers!!!
Old 06-01-10, 02:23 PM
  #106
LexISguy
LexISguy's Avatar
Any Idea what 416rwhp equates to the crank?
Old 06-01-10, 03:08 PM
  #107
Gymkata
Gymkata's Avatar
For the ISF, probably 475-480 crank hp.
Old 06-01-10, 03:38 PM
  #108
dsg03svt
dsg03svt's Avatar
Originally Posted by hblexus07
That is done quite a bit in the corvette world. Increase the WHP with the headers and maintain a fairly quiet exhaust note.
Well who cares about that world... :P
JP, I used to own an 01 z06 with headers and mild cam (basically just an 02' cam, since they were a little more aggressive than the 01's) and can attest to quite a few people doing just headers, but then again the z06's came with a ti-exhaust stock, so who knows...
Old 06-01-10, 04:11 PM
  #109
ftw
ftw's Avatar
480 hp range at the crank sounds about right. You usually loose around 15% to the wheels with a RWD car. Port and polish the intake and throttle body should take it close if not over the 500 hp at the crank. If we could tune the ECU this would also help maximize the hp potential of all these mods.
Old 06-01-10, 07:13 PM
  #110
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,082 Likes on 2,474 Posts
Not sure about the required back pressure but again in the vettes on a LS2 1 3/4" headers made more horsepower and torque than did the 1 7/8". The greatest loss was torque in the midrange (under the curve) where dyno test would show nearly 30 LB FT difference at the wheels. That was on a LS2 with bolt ons only, if we went with FI or heads/Cam then the 1 7/8" was the way to go.
Back pressure? Not again...bigger tubes present MORE pressure, not less. That's why you lose mid-range with bigger tubes.
Old 06-01-10, 08:48 PM
  #111
Juanca
Juanca's Avatar
Why is crank HP so important to you? I see you asking the same question in every single thread that talks about HP.
Old 06-01-10, 09:14 PM
  #112
hwy1isf
hwy1isf's Avatar
As I said, I was not sure about anything to do with "back pressure". We just tested headers with two different primary diameters on a LS2, and found the greatest gains on the NA engine to be the 1 3/4" vs the 1 7/8".
Some additional information on header design and exhaust theory.
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
Old 06-02-10, 08:00 AM
  #113
LexISguy
LexISguy's Avatar
I ask because I am curious what mods would give the IS-F 500hp. I know horsepower to the wheels is what really matters.
Old 06-02-10, 10:45 AM
  #114
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
^^ Best bet would be an LFA n/a motor....
Joe Z
Old 06-02-10, 12:06 PM
  #115
sweetbird
sweetbird's Avatar
when will the headers be for sale? and anyone no how they installed the headers without removing the motor?
Old 06-02-10, 12:10 PM
  #116
Splat
Splat's Avatar
elite is the ones who installed them with out pulling the motor. They supported it from the top and dropped the subframe.
Old 06-02-10, 12:12 PM
  #117
sweetbird
sweetbird's Avatar
cool, thanks splat!
Old 06-02-10, 12:19 PM
  #118
powmax
powmax's Avatar
You usually loose around 15% to the wheels...
very optimistic... remember: the loss curve is not linear
maybe or maybe not! LFA put only 430 WHP and 280 WT...
Old 06-02-10, 02:31 PM
  #119
MRxSLAYx
MRxSLAYx's Avatar
From what ive seen, 15-17% is a reasonable estimation. Also, remember that the isf and lfa have very different transmissions.
Old 06-03-10, 07:56 AM
  #120
jaslapp1
jaslapp1's Avatar
Elite isn't the only one. Sikky did the same thing with their headers. Follow the link on LexusF.com for all information about the sikky headers. Sikky is not a sponsor on clublexus.
Quick Reply: Headers!!!
