Custom Exhaust with Sound Clip
#31
took some digging to find this...
I recently installed the Joe-Z exhaust, and ever since I've been looking for ways to quite down the setup a bit. The noise/drone is slightly excessive for a daily car imo. I'm considering to do a similar setup as yours with the stock mufflers on the back... how do you like it so far? have you had the chance to compare your setup with a Joe-Z?
Hans
Hans
The JoeZ is a great exhaust, the fit, finish, workmanship and quality is impeccable, but it's too loud for me. IMHO, it's by far the best aftermarket exhaust system available for the F. Yes, I have heard it, and driven in a car with with one. Most of the users on this forum who have it luv it, but it's just not my cup of tea. I am very happy with my setup.
I am attaching a pict of the new cat behind the PPE header.
Lou
#32
Thanks Lou. I guess from your experience I was trying to gauge where would my modified setup (Joe-Z with stock mufflers) put me in terms of noise level.
In other words, if I tell you Joe-Z is a level 10 (out of 10) in terms of noise level, and stock is 1, where would you put a Joe-Z with stock mufflers on that scale? Would you expect the stock mufflers with straight pipe (like your original setup) be closer to what a stock IS-F sounds like or one with a Joe-Z exhaust?
I hope I’m making myself clear, or maybe my comparison isn’t really valid. I might just have to do it myself and find out first hand.
#33
^^^^That's a tough call. From my experiences, the tone, not the loudness is determined by the resonators. I have, supposedly, the least efficient kind of glass pack. It has spiral inner core with holes for the gases to pass thru. The more efficient kind, just has holes (or perforations) in a straight tube. I don't know what kind of resonator JoeZ uses. As I have indicated my exhaust is a lot quieter than the JoeZ, but much deeper in timbre than either the stock or the JoeZ systems. The one resonator in the stock system is straight round with holes.
There was a forum member who had the same issue as you, and he also contemplated mating the stock mufflers with a JoeZ exhaust. He solved his problem by applying liberal amounts of aftermarket insulation behind the back seat and in the trunk area. He reported that the drone and noise level inside the vehicle were reduced to levels acceptable to him.
IMHO, mating the JoeZ to the stock muffler would be a good move if you are wanting to reduce noise and retain and the excellent flow characteristics of the JoeZ system. The stock mufflers are a large capacity design. They are also heavy. Again, this would, IMO, quiet your system down, yet still retain good flow.
Lou
Lou
#34
You hit the nail right on the head lou! thanks for the in-depth analysis. Your final comment is exactly what I'm going for. It's really not just the noise level inside the cabin that's annoying, but my whole house rattles when I cold start the car in the morning! lol... to me, that's not acceptable. As long as my gains are a net positive from stock, I don't really care to lose a few HP to make for a much quieter ride.
Though I might be approaching this the wrong way completely... maybe I'm better off just getting a Borla axle-back exhaust and calling it a day, lol.
#36
Lou
Lou
That would probably be me. I was able to reduce the drone/resonance by about 2db with the placement of some B-Quiet material, but the best thing I did was installing the high flow cats which drastically reduced drone/resonance. So much so that I don't believe I would have needed to apply sound deading material to my trunk lid/backseat area.
As for the stock mufflers mating up to the JoeZ exhaust I too think it would be a great idea. They are actually not all that heavy and to me actually feel lighter than the JoeZ mufflers, but having them mated up would certainly prevent any drone/resonance and shouldn't reduce power by more than I'd say 5whp as Lou pointed out the stock mufflers are large capacity.
#38
^^^^Hey Grasshopper you're probably right. The two crush bends are in the back, so not really that much of a restriction. the front bends are now mandrel bends. The rear bends were made on a bender with a large diameter radius. The restriction is certainly much less than the crush Y in the stock system, oh wait you don't have a stock system in an F, you have a 350!
Lou
Lou
#39
...but the best thing I did was installing the high flow cats which drastically reduced drone/resonance. So much so that I don't believe I would have needed to apply sound deading material to my trunk lid/backseat area.
#40
Your best bet is to find some OEM mufflers to fit onto your JOEZ or order up some Dynomax Super-Turbo mufflers which are supposed to be one of the quietest performance mufflers on the market. http://www.dynomax.com/mufflers.php?muffler=superturbo
#41
Don't get me wrong, the exhaust was still loud, but did not have the drone/resonance issue for the driver. Your problem though would still be the same with regards to how loud the car is and potentially making enemies of some neighbors.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
uschardcor
Performance
06-03-07 09:49 AM
mrshabo
Performance & Maintenance
07-23-05 08:53 PM
