New IS F Short Ram Intake from AFE/Takeda
#48
FYI - i think i know why they have a step down...
so we've been working on an intake for the F as well...trying all sorts of new configurations to find out what works best
one thing we found out is that when you use a larger diameter tube, it affects the MAF sensor and throws codes...
we tried everything from moving the sensor location to different tube sizes and it seems that anything over a certain diameter tube will throw a code
if you look at the K&N pipe it's also stepped down right after the filter. i wondered about this and now i know why
we still haven't dynoed ours but i can tell you that it does make a small difference over stock (doesn't everyone say that though...haha)
as soon as we get the final design dyno'd i'll post something up...not too sure when this will be though... *sigh*
#49
^^ That step down process started at Injen many, many years ago...
Then it went to Fujita.. and now Afe/Takeda..
It's sorta an industry practice now..![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Also, K&N has caught on as well as every other open element intake manufacturer..
If you look at all the short ram/cone filter intakes made for the F, they all have the step down to 3" piping by the MAF area.. (not a coincidence)![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Joe Z
Joe Z
after all those damn tubes we made...
oh well...they make great...um...doorstops???
#50
Received 1,063 Likes
(it's not a coincidence)![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Joe Z
Joe Z
#52
Gentlemen.....to the undecided there seems to be a bit of a dilemna here.
One guy is saying the intake is a piece of crap.
Another is saying otherwise.
Who to believe???
Who to believe???
#54
i had tried to post pix before and had failed a few times. for those of you already purchased, look inside the tube and you might see what i meant. if you could fit your hand into the tube, you could even feel the very rough weld where the 3" tube joined to the 3 1/2" tube towards the engine side. whether any of these "minor" things affect performance or not is beyound me, i just wish they had done a better job. the airbox design is nice, but why not finish the job with a lightweigh box instead of using heavy steel and half of OEM box. a complete plastic box should be relatively inexpensive to manufacture and probably better. one of my reasons to get the intake is to loose some weight at the front corner, but that's obviously not the manufacturer's concern.
#55
in my original post, i mentioned that the exterior looks fine, but when i inspected the interior of the tube, that's when i found some "minor" sloppy weld job. my point was simply that it does not look like it's worth $400 not knowing its real gain.
I think typically intake gains are ALWAYS marketed as flywheel (except JoeZ.)
This is because if they weren't then people would have a hard time buying them. Any who would spend $50 on a dyno to verify a $300 investment. At that point who cares right? Its more about looks.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#56
1. I had not read your first post when I installed mine or I would have paid more attention to the inside of the tube. I remember I did look inside from end to end, and on my cursory look, it looked OK to me. If I missed something, I don't remember it.
2. Yes, the box is metal, but I don't think it's that heavy. It's lighter than the stock plastic assembly. Also the tube, IMHO is very light in weight.
3. I spent nowhere near $400 for my unit. In my original post I mentioned I bought mine from B2 Auto designs. They do not charge anywhere near $400 for this unit.
4. I have bought many third party after market devices in my time, and again IMHO, the quality of this kit is much better than some others I have seen in the past. Just as an example. On the K&N kit for the F, the filter is attached by two screws to the heatshield plate, on the Takeda it is retained by five screws. It's this extra bit of attention that impressed me about this kit. Of course, to me, the big draw here was the semi sealed intake box.
In the end we all have to make a decision based on our own feelings. Stay stock or go with the a DropIn replacement, JoeZ, K&N, Injen, or perish the thought the SRT.
I made mine and honestly reported my thoughts and feelings. I applaud Mica for making his feelings known. Now, based on these reports, you guys have a little more data on which to base your decision. Have fun
![Ohyeah](https://www.clublexus.com/forums/images/smilies/OhYeah.gif)
Lou
#57
i thank Fig and Lou for the clarification.
i guess i am just picky. i have filed and sanded down the protruding weld spots and planned to make an insulated air box out of aluminum to reduce weight. should keep me busy for the next few weekends.
#59
Having had this for a few days and driven around town and on the freeway, I can make at least one comment. I always drive in Sport Mode, because, to me, normal mode is really lacking in throttle response. Anyway, with this intake, throttle response seems a little sharper to me, I really like it. As I previously said, the sound is marginally louder (throatier) at part throttle. And yes, so far, I really like this new intake.
Lou
Lou
#60
As FIGS said the investment in tooling to make a cover out of plastic far outweighs the cost of having the steel cover welded and powercoated on the limited number of intakes they will sell for the IS F. They do make nice injection molded pieces for their BMW 335i intake but that also retails for $1200. Judging by what I've seen not many people on here would be wiling to pay that much for an intake.
Overall I've seen intakes on the market that consist of far less engineering that cost well more than the $400 "suggested" MSRP, which in no way reflects the actual street price this is being sold at.
