ISF REAR MEGA Arms and ADJ Toe links first renderings
I am still looking for an eccentric bolt setup to finish things off. I have ordered several sets and they all have a disqualitfying feature. I am still comitted to making ths happen, even if I need to run a set of eccentric bolts myself.
Fig
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
I have placed the sheetmetal on order for the first proto MEGA arms. I found an eccentric bolt for the outer mount so things should work perfect for on vehicle adjustment that way. Will keep you all posted.
Here are some pics of my current work on the IS 300 version.
__________________
Tech Info Resource
When will you have something for the front? I'm tired of the understeer...
__________________
I will try to get under there this week to see if these fit.
__________________
Trying to see where my laser cutter is at with these, I will advise once I get an update.
__________________
Its not just camber that is the issue, its toe steer. These will counteract the toe link to create a more predictable rear end during cornering. Also the combination with the Trac link will allow toe neutral camber adjustments, so you can run more neg camber if you wish.
__________________
