ISF REAR MEGA Arms and ADJ Toe links first renderings
Old 02-24-11, 09:06 AM
  #91
FIGS
The Maker
FIGS's Avatar
Thanks sold out.
These have been for sale on my site www.figsengineering.com
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 02-24-11, 08:16 PM
  #92
lx470man
lx470man's Avatar
im sorry to ask stupid question but what does this do for the car? I mean why would i buy this?
Old 02-24-11, 09:05 PM
  #93
flowrider
flowrider's Avatar
Received 1,926 Likes on 1,358 Posts
^^^^You may want to read this thread starting from page 1.
Lou
Old 02-24-11, 11:04 PM
  #94
FIGS
The Maker
FIGS's Avatar
The quick answer is to gain traction an to add adjustment capability to make the rear end track better (less bump steer and smoother cycling.)
__________________
Old 03-01-11, 09:23 PM
  #95
FIGS
The Maker
FIGS's Avatar
Finished product with powdercoating
__________________
Old 03-02-11, 09:56 PM
  #96
KJH
KJH's Avatar
Mike,
Do I know the owner of those?
Old 03-02-11, 10:13 PM
  #97
FIGS
The Maker
FIGS's Avatar
Originally Posted by KJH
Mike,
Someone in TX, so not sure
__________________
Old 08-14-11, 07:53 PM
  #98
jurutera
jurutera's Avatar
If i want just to remedy the premature wear from lowering, is the toe link enough?
Old 08-15-11, 03:19 AM
  #99
rhy
rhy's Avatar
Any plans for a front camber solution? Is it even possible?
Old 08-15-11, 08:51 AM
  #100
FIGS
The Maker
FIGS's Avatar
I have looking into front camber correction and so far its not possible on the upper control arm. I think th caster adjustment is more critical anyway in terms of tire wear as it makes it really hard to get the tire to roll over with as much as 11 degrees of frotn caster.
The toe links will allow mitigation of tire wear at a given camber angle, but to completely address it the MEGA arms are needed. Also keep in mind the other benefits like no bushing peload, sway enlink mount options and shock position options. It really helps with locating the rear and cleaning up the suspension cycle.
__________________
Old 01-30-12, 05:28 PM
  #101
Evil Teo
Evil Teo's Avatar
anything for the front...waiting for tax return to get these from u but not sure about the fronts.
Old 01-30-12, 05:32 PM
  #102
rhy
rhy's Avatar
I went to a local shop recently and talked to the guys about a camber kit for the front. They emailed me a few days later and said they found a front caster/camber kit for the IS-F and it would be in the $200 range. They didn't specify which one and never replied afterwards, but that almost sounds too good to be true.
Maybe it's the SPC one?
http://circuitmotorsports.net/spc67530.html
I'm swamped with work at the moment and haven't pursued this further.
Old 01-30-12, 06:47 PM
  #103
Evil Teo
Evil Teo's Avatar
Actually I am looking at those but they aren't good if ur car is lowered and my car is a little bit lowered.
Old 01-30-12, 09:04 PM
  #104
FIGS
The Maker
FIGS's Avatar
Teo, still working on it. We are still moving shops and I have one proto welded and ready to drive on as soon as we wrap things up.
The SPC ball joints always suffer from clearance issues since they push the control arm upward. There is no clearance on the upper side to make any kind of major adjustment due to the formed sheetmetal pocket that wraps around the inner fender. The only way to get meaningful camber correction will be at the bottom.
Besides that it seems that toe and caster are bigger issues in the front especially considering the large amount of steering angle and how it translates to ackerman angle during regular driving.
Mike
__________________
Old 01-30-12, 09:11 PM
  #105
rhy
rhy's Avatar
Does that mean that it's possible to get 2 to 3 degrees of negative camber via a correction at the bottom? That would make quite a few track enthusiasts happy.
Quick Reply: ISF REAR MEGA Arms and ADJ Toe links first renderings
