ISF REAR MEGA Arms and ADJ Toe links first renderings
#106
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#108
So the rims i have right now dont fit unless i run more camber, isf doesnt have any camber adjustments or none that i saw...
so if iget these arms It would allow me to add more camber correct?
also i saw 2 versions, whats the diference?
#109
~Sam
#110
Yes, this is one reason we added them to our F was to add camber as well as increase toe link arc length. For an 2010 or earlier this is the easiest way to gain a stable rear end and improve grip at the track. Minimal impact on tire wear with -2 degrees of camber plus the added benefit of running wider tires.
__________________
#111
The Race version is stiffer, lighter and designed to hold the power of the F. The EE version is a cost reduced version that is more for slammed ISx50 and Gen3 gs vehicles. While they both have the same adjustment ranges the RACE version is what we have tested under extreme loading and what we suggest for all IS-F owners.
Mike
Mike
__________________
#112
#113
see above lol.
__________________
#115
Links will always be heavier because we are adding solid threading components to a tubular assembly that used to be welded.
__________________
1BAD4DR
11-27-13 01:48 PM
meade916
IS F (2008-2014)
50
01-15-12 07:27 PM
