ISF REAR MEGA Arms and ADJ Toe links first renderings
Old 03-16-10, 10:32 PM
FIGS
The Maker
FIGS's Avatar
Default ISF REAR MEGA Arms and ADJ Toe links 1st Production built RELEASE VERY SOON
Here are my first renderings for a camber/toe kit for the 2IS/ISF, The toe link length and tubing design is not final, but the stud and HMA spacers are all on order or in house. I need to finalize drawings for the arms and get them on proto order. Stay tuned. Based on my S3 MEGA Arm design for the IS300.
updated...test installed this weekend, more pics on pg.3
Finished product with powdercoating
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 03-16-10, 10:44 PM
jadu
live.love.laugh.lexus
jadu's Avatar
oooh niiiice... Are they up for quote at a machine shop?? Is this in solidworks?
Old 03-16-10, 10:51 PM
FIGS
The Maker
FIGS's Avatar
yes. I will post up pics once I get protos. All the holes will be dimpled inward for strength. So they should be lighter and stronger than stock.
__________________
Old 03-17-10, 07:33 AM
anajri
anajri's Avatar
figs
Im building a is250 race car with the 3sge beams engine.. me me know how these goes im very interested to do this to my race car...
best regards
ALfredo Najri
Old 03-17-10, 08:10 AM
MR_F1
MR_F1's Avatar
Originally Posted by anajri
figs
best regards
ALfredo Najri
Got a thread with more info?
Old 03-17-10, 08:23 AM
anajri
anajri's Avatar
no not yet but i do have pics. ill open a thead later prob..
alfredo
Old 03-17-10, 10:29 AM
verals05
verals05's Avatar
awesome. I'm going to jump on these =)
Old 03-17-10, 10:05 PM
MR_F1
MR_F1's Avatar
alfredo
Gracias, lo espero con ganas.
Old 03-18-10, 05:35 AM
anajri
anajri's Avatar
jejej thanks it;s done check it out in the IS performance forums
Alf
Old 03-19-10, 04:51 PM
andrewshu3
andrewshu3's Avatar
Hi Figs,
So whats going to be the difference between your arms and tom's lower arms.
I'm still a nub so if could please explain what these will do for an is350 lowered on megan coils and sitting on megan rods and f-sport sways...
Old 03-19-10, 08:34 PM
FIGS
The Maker
FIGS's Avatar
Originally Posted by andrewshu3
Hi Figs,
Here is a simple comparo from what I can see of the TOM's
TOM's
-Stock arm that has been stiffened. (added weight)
-Perhaps stiffer inner bushing
-Nice powdercoating
-Stock adjustment (none)
-expensive and imported from japan
FIGS MEGA Arms
-Ground up designed to be light, should be about 2lbs lighter than stock. Dimpled for strength, minimized material, cross braced in essential areas.
-Adjustable: Shock angle, sway link connection, camber,camber-toe interaction.
-Rubber bushing replaced with 3-piece precision teflon-line rod end. Never any noise from metal on metal and salt spray life tested in numerous Colorado winters.
-Made to order to your custom specifications. Bare or powdercoated. Additional bracing or modifications available.
-Reasonably priced, cost projection is $400-$450/pr
A note on my arms, they are in use on competition grip, drift and drag cars Some over 800HP. They have been proven to stand up to a lot of abuse and provide extremely predicitable handling and precise control.
Here are a few pics of my IS300 versions.
Feel free to ask any questions.
Fig
__________________
Old 03-19-10, 10:59 PM
andrewshu3
andrewshu3's Avatar
looks sweet, whats the eta on these?
Old 03-20-10, 09:51 AM
FIGS
The Maker
FIGS's Avatar
I am getting in the S3 version for the IS300 this week and then based on how those go together I will make small changes and then get the ISX50 going. The one outstanding thing I need to see is if I should add the outer eccentric (need to create a bolt or adjustment mechanism) or keep a stationary outer mount and leave adjustment to the inner rod end.
__________________
Old 04-11-10, 10:22 PM
ambiguous
ambiguous's Avatar
Hope to see some new updates soon...Very interested!!!
Old 04-11-10, 10:26 PM
n0th1ng
n0th1ng's Avatar
i need an update also.. could use some camber RITE NOW! ahah just like .5 or 1..
Quick Reply: ISF REAR MEGA Arms and ADJ Toe links first renderings
