Complete IS-F Brake Thread (Under-construction)
#376
Sorry for the non-ISF question, but I believe setup in question is available for ISF and with this being the best forum around, I am hoping the get some feedback.
I did some work on my 09 Porsche Cayenne GTS today. I noticed, the front brake pads are almost in need to be replaced.
Just like my ISF, my Cayenne has the 2pc RacingBrake/Figs rotors up in front. Unfortunately, the Project Mu HC+800 are not available for the Porsche application, I am now leaning towards Ferodo DS2500 pads.
Questions:
1) based on my research, Ferodo DS2500 should be quite close performance-wise to the Project Mu HC+800 is that right?
2) how are these as far as the noise? (I don't care about the dust as I am all about performance.)
3) how aggressive are these for the life of the rotors?
Any other brake pads I should consider besides the Ferodos?
I am looking for the maximum performance with minimal noise, I also don't want to destroy my expensive rotors.
Questions:
#377
^^^^I have Ferodo DS2500 in front and PM HC+800 pads in back. I find that they are an excellent match. I've had the Ferodos for quite some time now, but as I recall they dust a bit less then the stock pads did, but grab and feel much better. I am very happy with them and when it's time to replace I will go with them again. Now for the record, installing RRRacing's A Arm bushings also changed the feel of the brakes. Again the USRS kit improved what I call the grab and feel. I luv 'em. As far as noise, once properly bedded in, there is none
My rotors still look god.
Lou
Lou
jv12 (12-26-16)
Bavarian (12-26-16)
#379
Former Sponsor
Questions:
Questions:
-Matt M.
#380
Hope everyone enjoyed their holiday weekend! You are on the right track looking at the DS2500- in my honest opinion they are the next best option if you care more about performance and less about dust. Like the HC+800 they have some potential to make a little noise during light applications of the brake at low speed (like parallel parking or creeping forward at a stop light). However if they are properly bedded they should be very quiet all the time. They aren't too terribly aggressive on rotors either so there should be no issues there. I was trying to look into the PFC's street pads for you but I need to know what rotor size you have. Have you already found the part number for the Ferodos or would you like me to find it?
-Matt M.
-Matt M.
do you guys reply to PMs or Emails? matt, I've personally emailed you, called, and PM'd on here. not one single reply for a month.
#381
-Matt M.
-Matt M.
The ferodo part number is: FCP1626H
#382
Former Sponsor
-Matt M.
#383
Former Sponsor
http://speedfreaksusa.com/i-21260644...-fcp1625h.html
http://speedfreaksusa.com/i-17719217...sche-rear.html
If you decide you'd like to order through us I can apply the club lexus discount for you
-Matt M.
#384
Got it- you need FCP1625H front and FCP1308H rear (if you ever need or want the matching rears). Here are the direct links for you:
-Matt M.
-Matt M.
I thought the pads I needed were FCP1626H, apparently not. Thank you for your help.
#385
This is my fault, I've been out with illness quite a bit lately. Mix that with the holidays, family, travel etc. and I fell quite a bit behind so I apologize. I still have nothing really to report on the RCF pads for you, everyone has been shut down and I wont have an update until next week but I should have emailed back to let you know. Again I am sorry for any frustration I have caused, I will do my best to make it up to you going forward if you give me the chance
-Matt M.
-Matt M.
Hope you feel better Matt. I saw the RCF pads on your website ready to be ordered which is why I've been messaging as of late. thank you.
#386
Former Sponsor
-Matt M.
#387
Sending you a PM as well but I just wanted to confirm my findings with the part numbers. FCP1626 and 1625 look almost identical, 1626 just has ~6mm taller annulus. All my literature is showing 1625 as being the OEM shape for a 955 4.8L S and GTS (w/ iron rotors) while the 1626 is for the 955 4.5L Turbos. Although both use 350mm rotors, they have a slightly taller swept depth/annulus. Brembo makes some great products but they can be a nightmare to work with because they make so many different calipers and caliper rotor combos (even within the same applications) that are just ever so slightly different and it always causes a ton of confusion Anyways I hope that clears up some confusion
-Matt M.
-Matt M.
Great, thank you so much for the expertise. Very impressed. It is awesome to work with real expert. The findings are correct, I have 2009 957 GTS 4.8L V-8. PMed you back.
#388
Here's the set up I'm thinking of for my new brakes:
Brembo OEM front and rear rotors: $629.36
http://www.discountpartsmonster.com/
They are a Toyota dealership in Hollywood, FL
Project MU NS400s front and back pads $397.90
http://speedfreaksusa.com/i-11667143...e-special.html
Total Parts: $1051.05
Does that sound right?
I imagine the labor to be $300-400 or so
I don't track the car and it is a DD. I drive fast but I'm not crazy peeling out or burning rubber. FWIW the OEM price on the front and back Brembo pads from discountpartsmonster was $421.69. So $23.79 more than the Project Mus.... So given the choice... Brembo OEMs or Project MU pads?
Any Thoughts/Suggestions/Input is very welcome!! Thanks!
#389
I think that depends on which attributes you value more.. If it's low dust/noise, the PMU pads win hands down. However, with those you'll give up some the initial bite compared to OEM & other more performance oriented pads. So, you'll have to adjust your braking force accordingly. If you prefer a quicker biting/more responsive pad, and don't mind some dust & occasional low speed noise, then stick with OEM or seek out a similarly priced equivalent.
I think the NS400 is great for a low dust, quiet street pad. I'm running them during the fall/winter, and will switch back to the Project Mu HC+800 when track season starts up again.
-Mike
-Mike
jv12 (12-28-16)
