Complete IS-F Brake Thread (Under-construction)
#406
Has anyone used this model below? some owner like it per the review. Weight 27.6 lbs/each !
Brembo 09.A300.11 UV Coated Front Disc Brake Rotor for $112 each.
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
This is the OEM Brembo rotor sold through Amazon. It's OEM , should work like OEM, nothing else to say except it looks like your gonna have to wait 1-2 months to get them. Yes, rotors are heavy and once you take them off you see how huge they really are on the ISF. If you want lighter ones get some shnazzy 2-peice ones.
#408
Originally Posted by ISF350
I really need help to buy a set of front rotor to replace the OEM rotor. My steering wheel is shaking when I hit the brake at the red light. I already bought a set of stop tech sports pads. Which brand for the front rotor should I get at reasonable price and look similar to slotted OEM ?
#411
Bed-in should take less than 15 minutes. just a heat cycle with elevated temps to get friction transfer. Is the DS2500 not too aggressive for the street?
We could have bundled the XT910 pads with the rotors if you contacted us Rossi, maybe next time. If you would like to give them a shot please let us know.
If anyone is interested we now have XT910 packages available with our 2-P rotors in stock for all 4 corners. It's a great spirited driving pad and the longevity of this compound with our 2P rotors means never replacing the rotors again on a street driven vehicle. Even with many track days on our set and they are still in great shape. We would not have had to service them if we had not upgraded to the 15", 14" kit on our car.
Thanks Mike
Thanks Mike
I would have to disagree on the XT910 pads as I used these with the Figs two piece rotors and honestly they were a disaster.
Pros:- Slightly less break dust over OEM and not that difficult to bed in.
Cons: - Performance at high speeds was scary in a bad way, for me it had close to no grip compared to the OEM pads.
- Noise when decelerating from very high speeds was also scary (maybe this was due to the 2-piece rotors) it made the loudest grinding noise when stopping from high speeds.
- The pads were pretty much done after a very very short period (Maybe 2 months) and they were done. When I replaced them the pads crumbled like a biscuit.
Honestly I'll never use the XT910 pads every again.
I've recently moved to the Project Mu 800+ and they're a million times better, much better initial bite, much better stopping power compared to the XT910 and OEMs. Yes they are more difficult to bed in but noise has become minimal now and I'm sure with a few more days of driving it'll go away.
Break dust is probably the only thing that the Project Mu 800 pads add but not worse than OEM and actually once the wheels are dusted well it looks like they're powder coated so I don’t mind especially given the improved performance.
Figs don't take this personally but I honestly have no idea how you guys can run the XT910 pads with your 2-piece rotors, maybe on OEM rotors they're fine.
#412
Former Sponsor
-Matt M.
#414
Tech Info Resource
Every time I drive the GS F, I miss the HC+800s. They just have such a great feel that the OEM GS F pads don't have. I initially push on them and they bite OK, but to get anything more, I really have to press. Not the HC+800s - initial bite is great, and if you want more, just press tiny bit and they seem to say, "Oh, you really do want to slow down - we've got you!"
#415
Also managed to bed them in well now there's no noise at all.
#416
Anyone have any experience with these brake pads?
Bosch BC1365 QuietCast Premium Disc Brake Pad Set https://www.amazon.com/dp/B008HZL8CE/ref=cm_sw_r_cp_apa_MymZyb4KS0RWT
#419
I'm running Carbotech 1521s now since I can switch between them and my track pads without rebedding.
#420
So something I was trying to find and did not see any topics discussing was pads and rotors for street/daily driving use that had low brake dust.
Decided to try out power stop Z-23 brake pads and centric premium rotors. Did the initial bed in process and drove about 100 miles this weekend. My initial impressions were less bite, no noise and otherwise fine. These are not recommended for track or high speed use (at least by me), but many corvette z-06 owners are running them and very happy with the low dust and comparable daily driving characteristics.
Oh by the way these are about $100 front and rear for the pads. If they perform as they do for the Vette folks I will be very happy with switching from the oem brembo pads.
