ISF Alternator
Old 04-10-10, 03:03 PM
verals05
verals05's Avatar
Default ISF Alternator
Does anybody know how many amps our alternators produce?
I'm installing a JL system consisting of a 500/1 amp and a 13TW5 sub.
Also I'm still running my ODYSSEY PC 680 battery and I don't want to put a different battery.
Does anybody know if this battery will still be able to support the sub and amp?
Old 04-10-10, 03:27 PM
HyperMKIV
HyperMKIV's Avatar
you should be fine.
i'm running 2 - 12" subs off a 1000 watt amplifier with the stock system
technically, once your car is started the battery is just a load and won't really matter with the system. it's more so the alternator that will take the beating after the car is started.
Old 04-10-10, 03:37 PM
jkeifer3
jkeifer3's Avatar
The battery by itself won't support it for long. Keep the engine running all the time even when your on the top of Mullholland Drive necking with your chick.
Old 04-10-10, 03:53 PM
BigA_IS-F
BigA_IS-F's Avatar
I wouldn't worry about it. Put in a cap if you are worried. I'm running a 1500w memphis and 2 JL 12" W7's with no problem in my 4runner with a 70amp alternator. I do have a yellow top battery but i'm having no problems and been doing it for 5 yrs now.
Old 04-10-10, 04:51 PM
LEXUSF
LEXUSF's Avatar
u have a class d amp and no need for a cap.
Old 04-10-10, 04:53 PM
LEXUSF
LEXUSF's Avatar
Originally Posted by HyperMKIV
you should be fine.
true and lexus parts are not cheap! u should be fine with a stock alternator with a small amp like the 500/1
Old 04-10-10, 05:54 PM
BigA_IS-F
BigA_IS-F's Avatar
Why would you say that?
Old 04-10-10, 07:19 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
Lexus IS-F Alternator = 12V 180A
Lexus Part number = 27060-38060
Also, used in the GS460.....
Joe Z
Old 04-10-10, 07:43 PM
verals05
verals05's Avatar
Yep.. its a Class D Mono Amp.
Joe Z
Awesome... I just didn't want to run into the lights dimming or anything of that sort... =)
luciush
luciush's Avatar
I'm pushing about 2000 watts from my sound system for a good 4 months now. So far it's still running normal! Lol
Zak92Sc400
Performance & Maintenance
07-13-15 08:47 PM
IC350
11-02-14 07:54 PM
gsean400
05-26-14 06:11 PM
adreano17
31
11-24-10 03:29 AM
AZN Lex
11-07-02 01:47 PM
Quick Reply: ISF Alternator
