Anyone else get a call from the dealer on gas pedal recall?
#122
After dropping off my car for an oil change this morning they said that by law they are required to address the recall. According to the SA, failure to do so could result in 100% liability for them and strict government sanctions if I become injured or cause any fatal accidents with the general public. SO I had no choice after all and ok'd the fix. :/
1.) Call Lexus Customer Service 1-800-255-3987 Ext 2 (for recall information) and to voice your displeasure.
2.) Opt out of the recall with the service advisor. Lexus (at the number above) says you can do that. Your service advisor merely won the battle of wills.
3.) Explain that if they don't respect your wishes, you will have your service and ownership experiences somewhere else, and state so on the customer satisfaction survey.
4.) Or...don't take it to Lexus.
#123
Lexus of Beverly Hills.
I figured it's a safety issue and dont plan on driving my car on track anyway so opted on getting the fix. The only displeasure is the funny looking smaller gas pedal were getting. I dont like it.
As mentioned above my only displeasure from this ordeal is the fact that theyre changing the gas pedal to a smaller one. Other than that I'm ok w/any safety enhancements/updates. I'd just thought I'd share my story with those who wish to go around the safety recall.
Actually you had several choices.
#124
Received 1,063 Likes
NO..... but that's just my opinion...
I have had 2 new Lexus' since 2007
The only time the cars saw the dealer techs, were during "PDI" = Pre Delivery Inspection.
Regards,
Joe Z
#125
After writing to my Lexus dealership (Stevinson Lexus of Lakewood Colorado), I received the following exceptionally courteous reply from the service manager. I don't know if it's okay to give out his name, I'd be honored to do so, but respectful of his privacy I should not.
I appreciate your position and you are more than welcome to decline the recall. The next time you bring your vehicle in for service, we will ask that you sign a statement saying that you were informed and understand what Lexus is doing and that you have declined to have the procedure performed. Obviously because this is a Safety Recall, Lexus has asked us to determine why the remedy is being declined and to make sure guests are fully aware of the entire procedure. During your next visit please forgive us if we spend just a few minutes with you going over the process per Lexus’ request and answering any questions you may have, however there will be no pressure to have the recall performed. Please contact me if you have any additional questions in the meantime, otherwise I’ll make a note in your file regarding this subject.
Thank you,
Service Manager
(303) 277-9339
(303) 279-7428 (fax)
Thank you,
Service Manager
(303) 277-9339
#126
Very professional response, it would appear he has been doing this job for a while and has an understanding of the situation. Great to see, well done to him.
#128
I agree with that.
But I think the brake pedal override should be defeatable when "VSC OFF" is selected.
This is the only car Lexus makes (currently) that has the option for switching VSC off. You already assume responsibility any time you switch it off.
I would take that a step further, that I believe in accepting personal responsibility any time I get behind the wheel.
Remember, this isn't a case of a manufacturer issuing a recall because of a defect. Lexus specifically states this is "for added driver confidence." When you fix things that are not broken, I don't get confidence from that, moreover the uncertainty of it becomes an additional distraction.
It's inconsistent logic to trust you to switch off VSC but not trust you with the brake and gas pedal when used together, or for the system to be trying to outguess or outsmart your intentions, whatever they are, for the instances of using the brake and gas together.
I couldn't care less about smokey burnouts. What I don't want to be thinking about, is that a decision to tap on the brakes while exiting the corner under power, could chop the power and send me looping into the gravel trap. Is it likely? Probably not terribly, but I don't want to be thinking about it at that critical moment. The distraction will command its own attention, and it's unnecessary.
#129
This is how my SA explained everything to me, and I signed the statement declining the update. It was at Lexus of North Miami.
Thank you,
Service Manager
(303) 277-9339
Thank you,
Service Manager
(303) 277-9339
#132
^^^ Hey ExclusivIS, you're right about my concern, the ECU update would have killed my ECU flash, but it wasn't my only concern. As people have stated before, that update would have become another nanny and I don't like them. As soon as I get into my car I turn VCS completely off and go into SPORT mode, so having that brake update and not being able to disable it would be annoying for me. Finally the tiny pedal looks ridiculous.
#133
I didn't. I don't care about a slightly smaller pedal that i've never noticed because of my big feet anyways. With a wife and baby on board, safety first.
Btw, I've noticed NO difference in performance. Then again I didn't take it to the track to prove it, nor will I.
#134
I declined not to have this done, not because I track my car, drag it, or drive it crazy..but because I didn't feel the need for them to mess wit my car if there's really nothing wrong with it. If anything they should be calling us to give us some damn dust free pads (That'll be the day!)
I still respect ur decision. I may get it done down the line, if there are good things to be said about it. Or if something were to ever happen, to put the car in neutral
