Recalibrating ML screen
None of the options on the screen worked Joe, I tried them all.
Saturday morning I'll be fixing the nav overide and leaving everything as OEM. I'll try the screen and diagnostics one more time, if that doesn't help I'll unplug the main harness and try again, if the touchscreen still doesn't respond then I'll take the car that same day to the dealer. Wish me luck guys!
Tech Info Resource
It really sounds like the touchscreen is damaged and has stuck at one location.
I went out and tested mine it says check under audio as well and mine is stock with no override. Pushing the check button brings up another screen that reminds me of hex code.
Tech Info Resource
Mine showed chk on audio. Usually it's because the CD/DVD play has an issue reading a disc.
I hit LAN Monitor on mine and saw a whole lot of CHK buttons. Not encouraging at all. I'll be looking up the codes this weekend when I have some time.
Mine is the same but I dont have any CDs or DVDs in my car at all other than the nav dvd I only use my ipod so I'd be curious to see what all the codes mean too. The clear code button did nothing.
Tech Info Resource
You have to hold the clear code button for a full five seconds to actually clear the codes.
Received 1,064 Likes
Oops... Forgot about that....!!!
BTW - did you how to enter the service menu by tapping the screen corners a few times in Display mode? ( thats how i get in there)
I know you mentioned the stalk method..
Jz
Tech Info Resource
I know both ways. I also know how to get to the secret sub menus once in the service mode.
The stalk method will work when the touchscreen is not working, that's why I suggested it on the off chance the alternate mode would release the stranglehold on the touchscreen. Sad it didn't help.
Tech Info Resource
I'll do some screen shots tonight.
Placeholder here...
Placeholder here...
