BCR spring rate
BCR spring rate
Hey guys I know there was a thread on this before I tried to find it and couldn't. What spring rate should I go with? I'm looking for better track performance but still a good ride on the street if I soften them up. Thanks.
The Maker
What track rubber are you going to use? That will make a difference also.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
What spring rate did CM put on your BCR order and what would you have gone with? I am looking into coilovers for my F also; it is a car that is primarily used as a DD, with occasional track events, so I have additional research to do myself.
I have given the input of what spring rate to you on BCR's but i think that 18k and 16k would be better. the car has a high roll point and its heavy. The spring does alot but the valve does more. i think the BCR IS-F set up should be at 18k and 16k for the standard.
