Some HELP with Alignment
Need some skoolin on alignments for our cars...
Just some background info...I have gotten one alignment done on my F after the coilovers were put on. Had this done at the dealership, and they told me I was pretty close to factory spec. (Even they were surprised for a lower car) Since I've got my works on, I have not touched or went for any kind of alignment. Im guessing there would be no difference going from the BBS 19" to an aftermarket 19" wheel, but what about when upping the diameter and going to 20's?
Should I go have another alignment done? And if so with 20's, what specs should I tell them to get closest to? Factory spec? Or what?
OH..just 2 add...-The car's been driving fine for me, and no problems with pulling to one side. I guess it's more about correct wear on my tires now.
THANKS!!!
THANKS!!!
THANKS!!!
THANKS!!!
If your current alignment is ok then you do NOT need another alignment if you change the diameter (only) of your wheels.
If you go for a wider width and rubbing is an issue, then you either increase negative camber or roll your fenders to fit them.
Tech Info Resource
Changing the diameter of your wheel (whether bigger or smaller) will NOT change your alignment.
Changing your wheel diameter alone with the appropriate reduction in tire size so that your overall diameter will not change will NOT change your camber, your toe in/out, nor your caster so both of you are incorrect as far as it changing suspension geometry with no mention of offset change.
Tech Info Resource
How many guys on this forum alone use narrower tires to stretch over wide rims so they can have "aggressive" offsets (whatever that means) and "stance" without any regard for what it does to their suspension geometry?
How many guys are running 245s in front and 275s in the back? No one makes a tire in these widths with the same rolling diameter as the stock setup.
So, yes, you are right, if the rolling diameter and the offset are the same as the OEM setup everything will be fine. Unfortunately, it's not possible to do this in the real world without fully custom wheels.
Legender
05-24-13 03:39 PM
