where to get a nitrous kit for our f's??????
Only run a wet kit. I only use Nitrous Express. The kit came complete but ive changed the solenoids since i bought installed everything.
This is basically the kit i have now just with different solenoids. Ive been through around 12 bottles and no problem with the kit. Just dont hit the speed limiter![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
http://nitrousexpress.com/product-details.php?id=888
sweet thanks man!!! and why did you change the solenoids?? do you have a fuel safety switch, or wide open switch? and can you pm me pics of your install? were you mounted the solenoids? thanks for all your help!
No Fuel Safety switch (should have one) but fuel comes directly from the rail so if there is isnt sufficient pressure there i dont think the car would run without a CEL. I do have a wide open throttle switch along with a TPS. If i still have time tonight ill take some pics and send them to you. But idk... Its my birthday and everyone around me wants to get me drunk lol so i doubt ill have my keys when i go downstars ![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
The ny-trex triple threat kit is a kit that works well with the novice installer, yet provides a clean install and safety features to keep you from damaging your engine.
Regardless of what you use, fuel pressure safety switch is important when running a higher shots of nitrous. You'd be surprised how much your fuel pressure can drop when you add a line off of your fuel supply. The length and diameter of the line come into play. Without this safety feature, you run the risk of a very lean mixture which would result in a very bad and very expensive repair bill.
I've used the Ny-trex kits on my other vehicles and I'm currently installing a 200 shot setup on my SC400. Currently I'm rebuilding and upgrading the internals of my engine to handle that kind of power, so I don't have any install pics on this care yet. I ran approximately 100 bottles through my Scion TC with a 100 shot for a year and a half. My dyno on the nitrous was 273whp and 298wtq. Much improved over stock.
I had a dry 100 shot on my IS350 with less safety precautions than a monkey with a hand grenade. Ive put 65+ bottles through it with a button spraying from the launch to the finish. The only problem I have ever had is 3rd gear slipped one time when I got on the freeway (not spraying). I went from a 13.7 to a 12.6 in the 1/4 and a 9.0 to a 7.9 in the 1/8th. I also achieved one of if not the fastest '60 times in the 2IS with a 1.7.
