Hey guys, do any of you know if the antenna on the roof can be removed (safely?) without damaging the antenna? how is it attached on? any input as always greatly appreciated!
Yes you can take it out and it is relatively easy:
1- Remove the back seat light (remove the lens, unscrew a couple of bolts, pop out)
2- From there you can access the one nut that hold the satellite antenna
