M3
#61
some links
http://www.lexus.com/models/ISF/feat...sion_Story.pdf
it does say its from the LS
but on lexus.com they say
"The IS F features a world's-first eight-speed Sport Direct-Shift transmission for seamless, lightning-fast shifting"
i assume its called the worlds first because its sport direct shift
in the pdf link it mentions how it was designed to be strong/quick for track use
also the car was tested at fugi
and the F logo I hear resembles one of the corners
http://supergt.net/supergt/circuit/fuji/crs_fuji.gif
its really a shame that more people arent tracking this beast if that is the case.
being a F branded lexus, im sure F will always mean performance, and performance almost always leads to speed and the track
#62
Get the renntech ECU upgrade to open up the throttle to 100% instead of 80% and then you'll definitely eat an F. Until then, it's negligible.
#63
+1 ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I'd be surprised if anyone here didn't look at or consider the M3 prior to getting their F (along with the C63). We all knew what we were getting into and made choices that were best for us as individuals.
It's not an issue of one car being "better" than the other. I respect the M3 but didn't want one.![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
P.S. As to the DCT discussion...there are stickys on the M3 boards discussing the multitude of problems they encounter (yes, Henry...I know they have gotten better
....but have not gone away). Not an ongoing issue that I would want to deal with. ![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
when we shopped for our m3, we drove the isf extensively (more than a few times), but unfortunately we never felt connected to the car. ultimately the m3 pleases us a lot more, but there are things on lexus that we do miss
#66
Received 1,063 Likes
^^ Don't forget to factor in Long Term reliablility.... ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
As a daily driver in Los Angeles..
I see all too often hazard lights on the side of the freeways/roads from the Germans.
But hey, its really a personal preference i guess.
Owning Lexus' for just about 10 years, I have never had to pull over for a break down, failure or tow.
Best Regards,
Joe Z
Best Regards,
Joe Z
#67
some links
Just like I said the ISF trans is off the shelf from the LS. The only real difference between it and the LS is the TCU programming to benefit the ISF. "Sport Direct Shift" is just a marketing term IMO from lexus and to me this trans is not that different from other automatic transmissions in the way it performs. Just because Lexus put some paddles on the steering wheel doesnt give the trans special abilities. It does shift firmer and quicker than a standard auto trans
Just remember this is the first F branded lexus. Some things they got right and some they didnt. This is a good platform to build on for the future ISF's
LOL stop drinking the Lexus kool-ade. Our ISF is a great car for the money and my main reason for buying it over a C63,M3, RS4 was toyota reliability, great service advisors and decent service cost. But it is not the standard all sports sedans are measured to. I can understand being loyal to your ISF but at least be open minded to view its faults and other cars good points.
#68
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Just like I said the ISF trans is off the shelf from the LS. The only real difference between it and the LS is the TCU programming to benefit the ISF. "Sport Direct Shift" is just a marketing term IMO from lexus and to me this trans is not that different from other automatic transmissions in the way it performs. Just because Lexus put some paddles on the steering wheel doesnt give the trans special abilities. It does shift firmer and quicker than a standard auto trans...
#69
#70
Wrong speed.. Wrong gear.. its going to downshift when coming to a stop or
slowing down..
Why would you want it to hold a higher gear in a lower speed..?
(A manual trans would bog or cause engine stall)
On the flip side in manual mode.. I have punched the gas in the wrong gear & got goose eggs..
So like everything else, it just takes getting used to using it for optimal performance, when needed.
Joe Z
#73
Well think about it...
slowing down..
On the flip side in manual mode.. I have punched the gas in the wrong gear & got goose eggs..![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Joe Z![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
slowing down..
Joe Z
Anyway drove the F today a bit and I am still amazed at how smooth, quiet and composed she is. Definitely the right choice for the wife and I. One thing I love about it for her sake is the power delivery is very safe (its not a off/on kinda deal). Now if I could just get her to stop getting flats and cut tires it would save me some money. On the first set of tires we had to replace 2 tires(last one had a intact piece of half a sizzor inside the wheel that was found by the tech when we replaced the set last month) and had 5 tires fixed from nails, screws in the tires.
BTW how is everyone doing on tire wear with the stock tires? We got 29,000 miles out of the bridgestones
And I do think most comments about the exclusivity of the ISF is true. A lot of people ask what kind of kit it is on the car.
![Dance 2](https://www.clublexus.com/forums/images/smilies/dance2.gif)
#74
The M3 has been at the top of my most wanted car for the garage for nearly 20 years. Regrettably it won't be seen in my garage cos i can't freakn afford one.
I valet all types of cars and drove M3s regualrly before and i just adored them...
Comes down to what you want and who you are, definitely the M3 for pulling chicks and turning heads...more of a driver's car too imo.
The F is no doubt more luxurious but where pure driving machine is concern i would think the M3 is >.
#75
I love to come in the ISF forum every once in a blue moon and read how discussions and comparisons are going. Except for the handful of people who track their cars and actually air it out properly, no one else will notice the difference in handling or performance between the F, M, or C63. It ends up being a matter of personal taste and what design rocks their boat.
Honestly, most of the people that drive these vehicles shouldn't take these cars to the edge because they probably cold not handle it anyway and would end up wrapping it around a tree or freeway pole.
Anyway, for those that have the ISF, keep enjoying them and loving them. You all have a great automobile on your hands and no need comparing and getting all ruffled. If my family lifestyle (meaning less than three kids) allowed for it, I would have jumped on an ISF when it first came out.
