Will this fit?
Will these tire and wheel combo fit the rear of the F without rolling the fender? I have stock suspension.
Wheels:19x10 offset 38
Tires: 265/35 19"
Thanks in Advance
Tires: 265/35 19"
Thanks in Advance
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Just some food for thought.
I had some nice tire rubbing/cutting going on, with stock suspension..
With this set up:
19x9.5 w/ a 35mm offset on a 265-30 Yokohama Advan Sport tire
Solved via DIY ..
(Not recommend for the novice)
_![](https://www.clublexus.com/gallery/data/4537/IMG_8675a.JPG)
Joe Z
With this set up:
Solved via DIY ..
Joe Z
After grinding the edges of the fenders did you guys just leave the paint alone?
any chipping of the paint? maybe a can of clearcoat will help?
Which is better grinding or rolling?
35 vs 38 offset...whats the difference?
^^ 3mm
j/k
A 35mm will stick out more than a 38mm on a 19x9.5 inch rim..
Same would apply to a 19x10 rim..
However, the 19x10 rim is a 1/4" wider on each side, which will push outward more.
After the grinding/cutting/shaving process.. I recommend to use the color matched touch up paint bottle and give it a nice layer of oem paint.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Joe Z
Joe Z
plastus
11-11-15 06:19 AM
