Is There a Rotor Replacement DIY
Old 06-16-10, 10:49 AM
wiredGS400
wiredGS400's Avatar
Default Is There a Rotor Replacement DIY
Hello,
I am considering doing the $1300 rotor and pad change myself. I have found the DIY for brake pad change, but not for the rotors. Does anyone know if there is a write up for it?
Thanks,
Michael
Old 06-16-10, 12:36 PM
ftw
ftw's Avatar
Seen some Raybestos brand front rotors for sale on eBay for $103 a piece. Don't know how good that brand and rotor is verses the Brembo stock rotors.
Old 06-18-10, 01:28 PM
wiredGS400
wiredGS400's Avatar
Thanks.
Anyone know of a DIY for the rotor replacement?
Thanks
Old 06-18-10, 09:18 PM
BB/F
BB/F's Avatar
Pull the caliper off and the rotor will come off. Two bolts. Pretty simple.
Old 06-18-10, 11:41 PM
hahahaf
hahahaf's Avatar
i dont think there is but we should have one
Old 06-19-10, 04:48 AM
houstonT
houstonT's Avatar
As BB said, 2 bolts hold the caliper in the back...take them out, pull off the caliper...rotor slides right off. It's a "floating" assembly...
Peter
Old 06-19-10, 09:21 AM
Autobacs
Autobacs's Avatar
Originally Posted by wiredGS400
Hello,
Thanks,
Michael
Is that how much it costs to do this at the dealership?
If it is, there is no way I'm not doing this myself considering how easy this is to do.
Old 06-22-10, 06:34 PM
mdsbrain
mdsbrain's Avatar
No, $1300 is about what the parts cost alone. Tack on a ton more $ to get a dealer to do it. Best price was from Sewell Lexus shipped.
Old 06-29-10, 10:22 AM
wiredGS400
wiredGS400's Avatar
Peter
Thanks. Any chance you (or anyone) know the torque spec for the bolts holding the caliper to the hub. Don't want to break the bolt or have it come loose on me.
Thanks,
Michael
Old 06-29-10, 10:50 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,962 Likes on 2,400 Posts
Here's everything you need to know for the front brakes:
Old 07-02-10, 11:25 PM
wiredGS400
wiredGS400's Avatar
Thanks for the help. That was just what I needed. Took about 2 hours to replace the rotors and pads, using a single jack and raising only one side at a time. Not bad if I do say so myself.
Michael
Old 08-11-13, 11:38 PM
seanphan
seanphan's Avatar
Has anyone done the rear rotor DIY? Or is it the same steps as the front rotors?
Old 08-12-13, 05:49 AM
caymandive
11 Second Club
caymandive's Avatar
Here is the DIY front rotor replacement thread. https://www.clublexus.com/forums/is-...ke-rotors.html
stevelifts
05-08-17 02:47 PM
CJITTY
02-17-11 12:34 PM
RobzKar
Suspension and Brakes
01-29-09 10:43 AM
badx33
09-19-08 12:03 PM
cenwesi
05-07-08 01:33 PM
Quick Reply: Is There a Rotor Replacement DIY
