Sorry Another Brake Question....
Old 08-16-10 | 04:56 PM
poorbong's Avatar
poorbong
Originally Posted by FIGS
Just created a step by on the fronts with the raybestos replacement rotors if anyone is interested. Pretty easy.
http://figsengineering.blogspot.com/...akes-with.html
do you have the part numbers for raybestos rotors?
thanks
Old 08-16-10 | 07:30 PM
BB/F's Avatar
BB/F
Also for you guys who do this yourself, while the caliper is off, give it a cleaning with some simple green and a soft toothbrush. It will get all the built up brake dust off, especially in the area where the caliper pistons are.
Good idea for cleaning the pins. I used a brass brush and it was a pain.
Old 08-16-10 | 11:22 PM
FIGS's Avatar
FIGS
The Maker
Raybestos 980675 $103.79
The write up could have been better I suppose since I left of the "finesse" steps. But I did take the better part of the weekend to detail it all and tried to take good pics.
And Simple green is simply the best. I was in a rush to get things back together otherwise I would have gotten down on it with the stuff. I keep a mix in a pressure sprayer
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 08-17-10 | 01:40 PM
eXstasy's Avatar
eXstasy
Nice writeup FIGS, thank you.
Question... is there any specific type of anti-squeal recommended? Can you use anti-seize? I know that some Lotus guys use it instead.
Old 08-17-10 | 04:25 PM
FIGS's Avatar
FIGS
The Maker
the grease is just high temp grease that was supplied with the pads.
Fig
__________________
Xzria
RC F (2015-present)
01-03-19 10:56 PM
Naren
NX - 1st Gen (2015-2021)
19
10-31-18 11:19 AM
Luscombe8A
05-16-18 05:44 PM
Dryrunner
08-31-15 07:58 PM
BelaRuski
Suspension and Brakes
11-08-10 08:25 AM
Quick Reply: Sorry Another Brake Question....
