Sorry Another Brake Question....
The dealer informed me my front brakes are at 3.5mm they measured it with a mirror and an LED, so i need to actually remove the wheel this weekend and measure them myself. I find it hard to trust them when all they used was a mirror.... Even if they are not bad i think i will replace them regardless because i'm tired of the brake dust.
So my question is do i really need to replace the rotors after 15k miles? I was planning on inspecting them and just replacing the pads with Carbotech 1521 and leaving the rotors alone until 30k. Is this what ever one else has been doing?
On a side note i could not stop laughing when he quoted me $1300 for a brake job. To install 4 brake pads what a joke!!!
Thanks,
Ken
Thanks,
Ken
I've heard of people replacing at 15 & 20K. My front rotors had a lip from wear but I reused them with the Project Mu pads I installed and they are fine. The next time around I'lll have to buy new rotors though.
I think everyones situation is going to be different so I would measure yours and determine if they need to be replaced or can be reused.
It was Lexus of Chandler and it did include rotors. I just have trouble believing my rotors will be shot after 15k especially since they are Brembo. But who knows maybe they are correct won't know until i pull the wheels off this weekend.
Thanks,
Ken
Thanks,
Ken
Touareg is another vehicle known for its expensive brake jobs. Many owners ended up replacing their pad AND rotors at 15 - 25k. At first, they thought they got ripped off, too...
Interesting I could of sworn that price was for just the front brakes, either way it's still to steep for a standard brake job that I could easily do myself. I just need to decide if I want to replace the rotors.....
So I went to Glendale Lexus with a one year old IS F 08 with brake squeal. They are changing the pads because of a brake bulletin. Are they just putting oem pads on or has Lexus ordered a new pad to solve the noise issue. I have nearly 9000 miles on the car. They are changing them under warranty. Thanks
The Maker
Just created a step by on the fronts with the raybestos replacement rotors if anyone is interested. Pretty easy.
http://figsengineering.blogspot.com/...akes-with.html
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
