15k service
15k service
I know it's debated, but do I really need more than the oil change?
Dealer is charging 82 for regular oil change.
Or $130.14 for the following:
15,000 mile maintenance service includes the following services:
[ ]00001R: Replace Engine Oil
[ ]00003R: Replace Engine Oil Filter
[ ]00004M: Reset Service Indicator
[ ]00005M: Road Test
[ ]0013CN: Clean Cabin Air Filter
[ ]0017IN: Inspect Body Paint and Corrosion
[ ]0021IN: Inspect Brake Lines, Hoses and Connections
[ ]0023IN: Inspect Brake Pads and/or Linings, Rotors and/or Drums
[ ]0030IN: Inspect Drive Axle Boots
[ ]0046IN: Inspect Exhaust System and Heat Shields
[ ]0061IN: Inspect Rear Differential Fluid Level
[ ]0069IN: Inspect Suspension Ball Joints
[ ]0071IN: Inspect Steering Operation and Linkage
[ ]0113IN: Inspect Engine Coolant Level
[ ]0227IN: Inspect Rack and Pinion Assembly
Just to be sure.....
Other than an oil change, a cleaning (cleaning?) of the cabin air filter, and possibly keeping your warranty intact, the remainder of the service could be nothing more than the technician at the dealer taking a one-hour coffee break. I'd request to have the dirt that was recovered from the air filter cleaning returned to you "just to be sure".......
Received 1,064 Likes
Oil & filter change and do cabin filter yourself. Depending on dusty condition from where you are, it may need to replace at 15k miles. Get few new ones on ebay, which *looks* better and costs much less than the newly updated version at the dealer. If DIY, be sure to follow the direction.
