Where can I buy cheap OEM brake accessories?
Received 1,064 Likes
^ I ordered up some Carbotechs 1521's this week
Just debating on the new rotors or reuse the ones I have with 24k on them..
My fronts for sure have developed uniform radial channels from the drilled holes.
Great Write Up Mike!!!
Joe Z
Joe Z
Tech Info Resource
Here is my suggestion. I am very happy with them so far.
http://figsengineering.blogspot.com/...akes-with.html
As corroded as your hubs are, I'd be hitting them with something to remove the surface rust. I'm very happy I don't live in a place with regular snow. I've not seen corrosion like that on anything I've owned ever since I left Iowa.
The bridge bolt is 13mm, not 14mm. The bleeder is 11mm as well. Euro sizes, not Japanese standard.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Jmags
Suspension and Brakes
29
01-19-11 04:13 AM
eboot
09-03-09 09:22 AM
