Found me some 100 octane today!
Old 10-08-15, 06:59 AM
  #31
2URGSE
2URGSE's Avatar
Originally Posted by ISF2NV
By the time he resets and the car relearns , he will need to buy another tank
Probably....
Old 10-08-15, 07:48 AM
  #32
DCoolBeans
DCoolBeans's Avatar
Without a tune or a reflash its a waste .
How will our stock edu benefit from 100 oct while its intended for 93. How would it know what to do
Old 10-08-15, 07:56 AM
  #33
2URGSE
2URGSE's Avatar
The thought behind is that I came from California 91 octane, now I'm running 93 octane and the car runs better.
Higher compression engines can benefits from higher octane, especially if you're running N20 (which I am not)
I guess I will see.
Old 10-08-15, 10:34 AM
  #34
Vervish
Vervish's Avatar
Theoretically, you would assume that the stock tune is designed to max out timing advance on 91 octane. However, even though the ECU has compensations for heat, humidity and other environmental factors, you can still end up getting some engine knock/detonation. The ECU will respond by pulling timing advance (which lowers HP) in the range the ECU heard the knock.. Higher octane will help fight knock, which can lead to the ECU adding more timing back, which leads to (a litttle bit) more power. This all assumes that you are not getting the full timing advance in the first place.
Vitveet
IS F (2008-2014)
04-26-16 09:50 AM
Jabberwock
03-13-15 07:03 AM
RonLNY
Hybrid Technology
14
08-11-11 11:54 AM
JT29
HS 250h Model (2010-2012)
06-29-11 07:01 PM
jskennedy
RX - 3rd Gen (2010-2015)
34
06-24-11 02:39 PM
Quick Reply: Found me some 100 octane today!
