Dealer Oil Changes
Dealer Oil Changes
Maybe I'm a bit too **** for my own good but wanted to throw this out since I have nothing better to do right now than waste bandwidth. I have always done my own oil/filter changes just because I still enjoy doing them and doing them kind of keeps me in touch with my car in terms of being able to spot mantenance issues. I do however take advantage of the first "free" oil change offered by the dealerships.
I have had three new cars back dealerships for those first oil changes recently, my is350, a new RAV, and my ISF. All three have come back at least a half a quart over filled. The 350 came in at over a quart.
I engaged the service manager in a discussion regarding the 350. He politely told me I was wrong and he would be glad to send a tech by my house to show me how to check my oil. No thanks. I did my own oil and filter change on the car and measured the oil that came out of it. Sure enough it was over a quart over spec.
All of these words just to ask... is this routine or a regular occurence for dealer done oil changes. I'm three for three in recent months. Worth noting, I took my first IS350 in for its first change and they only refilled it with five quarts. ****, probably but I'm not a big fan of dealerships because of little things like this.
When I drove across the country, the dealers I called couldn't work with my schedule. So I had to look for options. Oddly, I had great service at the 2 Walmarts I ended up getting the oil changed at. Both centers would consistently fill, and check the dipstick several times until it was spot on. Normally a quick lube or walmart would be my last option but it worked out. Now that I'm back home, I slapped a Fumoto valve on, and will continue doing changes myself.
Received 1,064 Likes
For DIY oil changes... It should be pretty damn easy on the F (even for the dealer)
But as you can see, even if you bring them 10, they put in 8.
Pour in 10 qts and you’re done.. Just have to make sure it’s been properly drained and of course oil filter changed..
I have done my own like 4 times already.
All I do is buy 2 - 5qt jugs and check it the next day.
It's always spot on.
Little known fact,:
Generally speaking, the "LOF" dealer oil change Tech is lowest on the Tech experience totem pole.
(LOF= Lube, Oil & Filter)
Joe Z
Little known fact,:
Joe Z
Thanks for the replies. I always have been and am definately on board with DIY oil changes. Just got into the habit of bringing a new car back to the dealer for the first one because they are usually free and I can resolve any new car issues during the visit. (Never had been one with any of my Leuxs's or Toyotas though).
Will put a few more miles on the F car, grab me a wheel barrel full of Amsoil (10 qts..... ching gow!).... and do my own oil changes from that point on.
Cheap editorial diversion: Are these great cars or what?!?! Reluctantly traded my squeaky clean s2000 and '09 350 for my currrent ride... I miss the Honda every day until I fire up the Lexus and head out for the day. Again, thanks for your comments!
giantdefy
02-07-10 10:59 PM
