Aggressive fitment IS-F pics!
#466
The Maker
Keep in mind if you are adding camber at the trac link you will push the wheel backwards. We also make most of the links and can customize length and rod end quality. We should have the trac link in the next few weeks. The rear lca should be built with power in mind so consider that when upgrading. Bump steer is the big consideration as well when doing this.
Mike
Mike
#471
The Maker
Haha, Ohlins takes forever but it should be worth it to fill the gap. Still waiting.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#472
#476
