Hi guys i need advice, i'm planning on test fitting the enkei RPF01, i was told that the 19x8.5 +42 and 19x10 +22 will fit without any issue(scratch caliper and clear bbk..). Now i'm thinking if i can go further with 19x8.5 +22 or 19x9 +18 in the front and 19x10 +22 in the back, thanks!
Small tires isn't a problem. My car is dropped on springs but I'm not sure if I'm going camber. Do you think I will run into problem with that set? (19x8.5 +22 and 19x10 +22). Thanks for your help!
the front no, but the rear you will rub without a roll and maybe some camber. Maybe a little strech tire will help also.
Hi changed my mind, i'm going with advan GT 19x9.5 +35 Front and 19x10.5 +25, what kind of work do i need to make this work? (how much cmber and tire size etc..) Thanks in adavnce!
front is no problem, but the rear, you will need camber/toe arm for sure. Im guessing -3+ camber depending on your stance and your tires set up.
