Do you think Volk VR G2 19x9.5 +42 will work for the front of the ISF? I want to put these on the front and get VR G2 Type 2 19x9.5 +35 for the rears. 255/275 tire combo
stance fitment for the widest you can get away with a 10" up front would most likely be 255/35. not sure about stock height. At 19x10+33 with 255/35 front is pretty close for me already. Any more would rub, and with a 285/295 you might have some rubbing issue with the suspension/hub.
Do you think Advan Rz-DF 19x9 +25 and 19x10 +35 will fit? Sorry for all the questions. I want to know my options before buying. I don't want to do any mods to make fit.
NO. You do not need a pull. You might be able to get away waith no roll if you run stock tires size. I have a buddy that's running a little aggressiver in the rear with no roll in stock tires size. Falken 452 is the brand he ran. Also his stance is pretty low. Feel free to confirm Kevin
Love those rims! Depending on tire, you might need to roll/shave the rear fender.
Confirmed .
I am running a 19x10 +35 in the rear with Falken 452 255/35 no roll whatsoever. No rubbing at all unless you hit dips going above 50-60, plus I am tucking the top part of my tires so you only see the sidewall. If your area has a lot of dips than I recommend rolling, no pull needed, because after some dips, my wheel edge was scraping against my fender. Took some paint off my wheels
