Aggressive fitment IS-F pics!
Old 11-06-13, 03:31 PM
  #526
LiLS
LiLS's Avatar
coming soon...
19x9.5 +10 / 19x10.5 +10
Old 11-06-13, 06:14 PM
  #527
chrisp1
chrisp1's Avatar
Originally Posted by LiLS
coming soon...
dang homie!
Old 11-09-13, 12:56 AM
  #528
HellaInc
HellaInc's Avatar
Anyone know if i'll be needing fender work for 19x9.5 +24 245/35 19x11 +29 275/35? I'm only lowered on Swift Springs at the moment, looking to get coilovers soon and getting 30 series tires in the rear. Will I need major fender work to run that tire size or what is the best size to run? I don't want to stretch too much nor do I want to rub AT ALL.
Old 11-09-13, 01:10 AM
  #529
CalitriSC
CalitriSC's Avatar
The front is fine but the rear would need major body work.
Old 11-09-13, 01:46 AM
  #530
HellaInc
HellaInc's Avatar
I was more worried about the fronts. But would I get away with a roll and slight pull and running a smaller tire?
Old 11-09-13, 02:22 AM
  #531
MK4Sup_isF
MK4Sup_isF's Avatar
I'm on 19x11.5 +40, which sits similar to 11 +33. So your rears are 4mm more aggressive than mine. I'm on 285 30 so your 275 30 will be similarly stretched like mine. I'm on -3.5 camber and shaved fenders in there rear. I guess you will need to be -3.8 or so to clear
Old 11-09-13, 02:41 AM
  #532
HellaInc
HellaInc's Avatar
I don't have tires yet so I might be stretching 225/40 and 255/35 for now until I get new tires and slam it on coils. Are you running control arms for your camber. Did you just shave your fenders or shave + pull?
Old 11-09-13, 11:59 AM
  #533
MK4Sup_isF
MK4Sup_isF's Avatar
I'm running upper camber arms. My buddy did the fenders shaving for me, not sure if he pulled the fenders a little or not. I dropped off the car and went to work so he did his things without me being there.
Old 11-09-13, 07:48 PM
  #534
HellaInc
HellaInc's Avatar
Thumbs down
Tried them on today and my rears wouldn't clear BBK... Got a 3mm space to see if that helps but waiting to get my alignment first... Sorry for crappy instagram pic... Will take better pics soon.
Old 11-09-13, 08:11 PM
  #535
CalitriSC
CalitriSC's Avatar
Looks good with the S1s! Make them Work.
Old 11-09-13, 11:10 PM
  #536
HellaInc
HellaInc's Avatar
Yes I will bro ! How much camber r u running with what fender mods if you don't mind me asking
Old 11-10-13, 10:19 PM
  #537
CalitriSC
CalitriSC's Avatar
I just have rear fenders rolled flat, tiny pull, and natural camber.
Old 11-10-13, 10:52 PM
  #538
HellaInc
HellaInc's Avatar
What tire sz you running front & rear ? I'm think about going 235/35/19 and either 265/35 or 275/30 for rear. And did you need to run spacers on your meisters to clear the rear BBK's?
Old 11-10-13, 11:44 PM
  #539
CalitriSC
CalitriSC's Avatar
I have 245/35 front and 265/30 rear. Yea my low disc clears front and rear
Old 11-11-13, 03:28 PM
  #540
HellaInc
HellaInc's Avatar
just ran into more problems today, tried on the 3mm and 5mm spacer today and my rears still don't clear BBK, I need at least a 10MM spacer to clear, my options are now to run the 10mm spacer with extended studs/bolt on 10MM and shave down my oem studs which puts my rear offset to +19... or run 5mm and shave down my rear brembos just a tad so that they clear. What are your guys thoughts ?
Quick Reply: Aggressive fitment IS-F pics!
