Aggressive fitment IS-F pics!
#971
It'll fit pretty nicely. It will also depend heavily on the tire sizes you want to run, Eddie. But I know that rear works in that size with either 275/30 and 275/35 with coilovers. Fronts shouldn't have too much of an issue, if at all.
ThisOldNSX (11-04-22)
#972
Custom finished WedsSport SA-55M's with machined faces and grey pockets. 19x9 +38 with a 15mm front spacer so effectively +23 in the front and 19x10 +40 in the rear. 245/35/19 275/30/19.
![](https://c3.staticflickr.com/6/5767/30874701770_f3ec874019_b.jpg)
![](https://c4.staticflickr.com/6/5657/31242372595_27fd465197_b.jpg)
![](https://c3.staticflickr.com/6/5720/30874702090_c6664c84e4_b.jpg)
The following 2 users liked this post by BirgeyT1:
IronNam (01-13-18),
#974
So I know for TE37's that 19 x 9 +35 are fine for the fronts without any fender work, I have the opportunity to maybe pickup some TTA second hand, but the specs are 19 x 9 + 35 both front and rear.
Would this look ok in the rear? Or would it sit too far in?
Not really looking for spacers as a solution either.
Only reason I ask is because these are pretty much discontinued and may be hard to come across in the exact front and rear spec's (rears being 19 x 10 +35)
