Offset and tire size are going to be the deciding factors.
I am running 275 on a 10" wide ET40 wheel with zero rubbing and no fender mods. I would think you could probably do up to 285s on a 10.5 wide wheel with greater than +45 offset..
Just got some good used tires for next weekends open drift, (still recouping from a wreck at the track years ago, the rest of the car is maintained very well just wish I was a little better at auto body)
Front: 19x8.5 30 offset with a 255/35/19
Rear: 19x9.5 40 offset with a 285/30/19
rear needed a roll and pull front did not
fitment is perfectly flush with no rubbing
Silver is not my style, but your car is an exception. Very good looking.
Thank you. Funny you should say that prior to my ISF I wasn’t a fan of silver until I had it. I really wanted a blue or red ISF. Owning a silver one is awesome because it hides imperfections so well and looks clean almost all the time.
I tried running a quick search.. but does anyone know if our cars can handle 19x10.5 +22 19x11 +23 ? Assuming fender pull is necessary and honestly don't want to do any crazy stretched tires to force these wheels to fit. But a mild stretch, I'll be ok with.
gonna need a lot of work, camber and stretched tire
that rear is absolutely gonna need a stretched tire. I test fitted 20x11 +28 on a stretched 255/35.
