Swift Sport Spring review for ISF!
Old 05-09-16, 12:27 PM
  #91
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
Originally Posted by GS4_CS
Whats the best/cheapest to get these? Modinjapan?
PM ME
Old 05-09-16, 12:35 PM
  #92
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
Originally Posted by Vitveet
Recently installed mine as well a few weeks ago on my 2012 F. Rude quality def took a plunge. Was a disappointment to me actually since the ride quality was SUPURB before lowering. Went with the Swift springs since everyone praised the ride quality and was supposed to remain "factory feeling". But looking back on it, everyone who praised the ride quality/comfort after lowering on the springs has an '08-'10 F that didn't have as comfortable of a suspension as the late model Fs....
But mine isn't a daily driver so I can deal with the little bounce that's present. And only " bad" over rough roads.... And not really even bad then honestly.... Just noticeable to me. But looks so good that I can deal with it :-)
Guess I need to get an alignment now....!
V.
It's expected to have the ride a little more harsh on Swift Sport springs since they are shorter (travel on the shocks are slightly shorter now) and the spring rates are stiffer to maximize handling performance. Swift does the proper R&D for spirited / track driving without compromising too much on the ride quality but it won't as comfortable as OEM of course.
Old 05-09-16, 12:44 PM
  #93
Diesel350
Diesel350's Avatar
Would there be any benefit in just having the fronts installed to reduce the bounciness?
Old 05-09-16, 02:22 PM
  #94
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
actually it's will be less beneficial not installing all 4 springs, keep in mind that the set was engineered to work together so if your spring rate is too weak on the rear, more chances of you breaking lose ( traction and handling)
Most drift cars remove rear sway bars for that reason
Old 05-09-16, 04:47 PM
  #95
ISDAS
ISDAS's Avatar
any brand closer to OEM in terms of ride quality or is swift the best bet? (springs)
Thanks.
Old 05-16-16, 08:32 PM
  #96
FFM
FFM's Avatar
Anybody in here got a used set compatible for a 2011 they want to get rid of?
Old 05-16-16, 10:14 PM
  #97
FIGS
The Maker
FIGS's Avatar
The results will also vary depending on the condition of your factory shocks. Things age and shocks will lose around 2-5% gas charge annually plus seal wear etc will cause further leakage. If you have mileage or time on your car then you may just evaluate going with 2012+ shocks and getting the swift springs for that version. Its monotube after all and has much better damping characteristics. Springs control gross travel limits but damping controls ride quality and the overall suspension response. Of go coilovers and we can set you up with a very comfortable ride and the performance to meet your needs and still use the best springs on the market.
We would be willing to offer a plug and play 2012 setup with swift springs pre installed for those that are interested.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 05-16-16, 10:23 PM
  #98
DjMarkOne
DjMarkOne's Avatar
Mike
With new oem tophats and fully assembled?
Old 05-16-16, 10:56 PM
  #99
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
i have New in box 2008-11 Swift springs in stock. If you can't find any used one's PM me.
Old 05-17-16, 12:19 AM
  #100
dabs
dabs's Avatar
Price Please?
Old 05-17-16, 07:49 AM
  #101
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
Originally Posted by dabs
Price Please?
you have PM
Old 05-17-16, 08:51 AM
  #102
Diesel350
Diesel350's Avatar
Mike
Thanks, so what your saying is that BC coils will offer much better dampening than the 2012 shocks in good condition?
Old 05-17-16, 12:22 PM
  #103
FIGS
The Maker
FIGS's Avatar
Yes we can do that.
__________________
Old 12-29-16, 12:12 PM
  #104
Anatoliy
Anatoliy's Avatar
Yes we can do that.
What are the best settings for BC coilovers on 2012 IS-F?
Old 12-30-16, 07:36 AM
  #105
Kojak77
Kojak77's Avatar
As stiff as possible.
Quick Reply: Swift Sport Spring review for ISF!
