Just installed KW Variant 3
Old 11-22-10, 05:09 PM
carlosg
carlosg's Avatar
Default Just installed KW Variant 3
I just picked up my car with the new suspension and must say is night and day.
got my suspension cornered balanced, aligned and new set of pilot sport ps 2.
Overall the suspension looks sick will have to wait for it to settle down cuz I got some noise on my driver side which could be the helper spring everything was double checked and in order but still got some noise on uneven roads.
Will be selling my Tein H springs.
Old 11-22-10, 08:22 PM
weaponX
weaponX's Avatar
Still waiting for mine.
I thought you're supposed to align it only after putting some miles/kms on the new suspension?
Old 11-23-10, 06:25 AM
sweetbird
sweetbird's Avatar
how much did the set up cost ya?
Old 11-23-10, 06:46 AM
carlosg
carlosg's Avatar
Got it off ebay at works concept, great service and price contact them.
Old 11-23-10, 07:21 AM
Civic Si-r
Civic Si-r's Avatar
How is the alignment so far???
Have any pulling to the right or left??
WIll you realign the car when the suspension settles in????
Old 11-23-10, 06:33 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,969 Likes on 2,403 Posts
Suspension doesn't settle in. If it was correctly installed, there's no need to wait for anything. Toe does need to be reset to prevent excessive inside edge wear, but there is nothing else adjustable, so if there are other issues, you won't be able to do much.
Old 11-23-10, 07:09 PM
FIGS
The Maker
FIGS's Avatar
soon enough you will have full alignment capabilities, at least in the rear.
Also looks like KW cracked down on distribution with a MAP price. So everything is going up about 10%. Looking at hosting a GB here for DEC on these.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 11-23-10, 07:21 PM
john09ISF
john09ISF's Avatar
I am curious to hear more about the noise you are referring to. It is my understanding that the KWs use some parts from the stock suspension. Could it be coming from the installation of those parts?
Here are the links to the store he bought it from:
http://www.worksconcepts.com/kw_susp.../i-306413.aspx
Their e-bay listing has it at $2,395 as a "make an offer" listing.
http://cgi.ebay.com/ebaymotors/KW-V3...Q5fAccessories
Old 11-23-10, 07:42 PM
weaponX
weaponX's Avatar
So you recommend I do an alignment when the coilovers are installed (and not put kms on it first)?
Old 11-24-10, 01:00 AM
avgj0F
avgj0F's Avatar
According to KW v3 Installation Instruction, It is common for the vehicle suspension to settle by an additional 5 - 10 mm (.2 - .4 inches).
Just curious, what made you so sure?
Old 11-24-10, 12:31 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I've done this quite a bit. If the bushings are reset to neutral, there is no "settling". The springs might sag, and if they do, they're crap springs, but suspension doesn't "settle" IME.
If you pull the OEM shocks and just stuff the new stuff in place without setting the bushings to neutral at static ride height, then you'll see what people like to call settling. It's actually the bushings breaking down because they're constantly stressed. The rubber finally gives up the ghost after awhile and this is what people call settling.
If I had a manufacturer telling me to expect the additional drop KW describes in their documentation, I would throw their springs in the trash without ever installing them and buy something good like Hypercoil or Swift. They are well known for not sagging even under racing conditions.
Old 11-24-10, 05:27 PM
carlosg
carlosg's Avatar
I have never felt the pulling, always straight.
will adjust some of the firmness but the ride difference is night and day. this is how this car should have come out from factory.
Old 11-24-10, 05:29 PM
carlosg
carlosg's Avatar
Install them and have it aligned and corner balanced
Old 11-25-10, 04:55 PM
GSteg
GSteg's Avatar
Although KW is a reputable brand (at least more so than others), what they're stating is what gives people the wrong impression that spring/coilover 'settles.' As lobuxracer said, most genius tend to tighten the bolt without preloading the suspension. It is possible that you won't get your bushings perfectly neutral unless you have the car raised on an alignment rack where all corners are loaded like they should, but loading one corner at a time is much better than not doing so at all.
If you're replacing your spring insulator, or your new coilovers come with one, then there will be some 'settling' because rubber will compress; however, we're talking about such a small difference that it's negligible.
In short when it comes to springs:
settling = sag = crap
Old 12-02-10, 08:36 PM
eXstasy
eXstasy's Avatar
Anyone come up with a solution to accessing the upper rear adjusters on the KWv3s once the interior is reinstalled? Any extenders that we can poke through the trunk lining?
Quick Reply: Just installed KW Variant 3
